Detecting chip from UART, but unable to flash / dump the code to detected chip.
Vinayak
Postby Vinayak » Thu Dec 09, 2021 4:49 am
Hi ESP Community,
I am trying to flash code to ESP32-D0WD-V3 (revision 3) which is on custom board. I am able to get the Chip ID and MAC address of the device. But, code is not flashing. I am getting the following error message.
esptool.py v3.1-dev
Serial port COM3
Connecting........__
Chip is ESP32-D0WD-V3 (revision 3)
Crystal is 40MHz
MAC: c4:dd:57:93:7f:64
Uploading stub...
A fatal error occurred: Invalid head of packet (0x65)
CMake Error at run_serial_tool.cmake:50 (message):
python C:/espidf/esp-idf/components/esptool_py/esptool/esptool.py --chip
esp32 failed.
msgluk
Re: Detecting chip from UART, but unable to flash / dump the code to detected chip.
Postby msgluk » Thu Dec 09, 2021 10:50 am
I had one module that could not be flashed. It turned out that the memory chip was upside down and not soldered.
Users browsing this forum: Bing [Bot], Google [Bot], PerplexityBot and 7 guests
