ESP32-S2-HMI-DevKit-1 help
Posted: Thu Dec 09, 2021 7:56 am
by sluurpie
Hi
I recently purchased ones of these to try the smart panel.
I have checked and its set to the following options in the menuconfig
(Top) > HMI Board Config > HMI board: Select board version. By default, please select ESP32-S2-HMI-DevKit-V2;
(Top) > HMI Board Config > Audio HAL: Select audio output interface, whether to use PWM or DAC;
(Top) > HMI Board Config > LCD Drivers: Select display IC type for LCD. By default, ESP32-S2-HMI-DevKit-1 uses RM68120 as its display IC;
In (Top) > Component config > ESP32S2-specific, please go to the Support for external, SPI-connected RAM option:
Go to SPI RAM config > Set RAM clock speed, and set the PSRAM clock as 80 MHz clock speed;
(Top) -> Component config -> FreeRTOS: set Tick rate (Hz) as 1000.
But my display shows this.
Please help?
Is my screen damaged on arrival or is there settings need to change?
Re: ESP32-S2-HMI-DevKit-1 help
Posted: Wed Dec 15, 2021 6:58 am
by Eavo
