I am trying to set up the ESP-IDF in CLion (following this tutorial: https://www.youtube.com/watch?v=M6fa7tzZdLw).
It fails while doing the Python dependency check with the message "Python: C:/path/to/python, Error: Access denied."
I tried to install Python in several locations on my drive (tried: C:\Python38; C:\Program Files\Python38; and the default Python installation folder C:\Users\username\AppData\Local\Programs\Python\Python38)
No one of them worked.
I am using Windows 7.
Does anybody have a idea how to fix this error?
ESP-IDF cmake Failed to run python dependency check
Re: ESP-IDF cmake Failed to run python dependency check
I find this problem too. you can look this but it is Chinese on 3.1.2 you can find The solution to the problem I am Chinese I can not talk more English .
I hope I helped you.good luck!
- IMG_20220810_133807.jpg (1.05 MiB) Viewed 2099 times
Users browsing this forum: axellin and 191 guests
