Question : esp32 no works after flash binary
turing_chang
Postby turing_chang » Mon Dec 20, 2021 1:06 pm
Hi All,
i flash binary into ESP32-S3-USB-OTG by flash_download_tool_3.9.2, but the esp32 didn't work, without any lcd and led.
The start address of binary is zero, not start from 0x1000, does any possible solution for that ?
B.R.
Re: Question : esp32 no works after flash binary
Postby Sprite » Tue Dec 21, 2021 1:44 am
The S3 code is supposed to live at offset 0, so that's correct. What binary are you flashing? Note that the ESP32 and ESP32S3 (and -S2, and -C3) are not binary compatible; you need to have a binary that is compiled for that particular chip.
turing_chang
Postby turing_chang » Wed Dec 22, 2021 6:49 am
Hi ESP_Sprite
the chip is used to esp32s3, the tool chain is esp-idf, there're three binary files after compiler done, bootloader.bin, partition-table.bin, and hello_world.bin. It does not work.
the target board is "ESP32-S3-USB-OTG", the information is listed as below link :
https://docs.espressif.com/projects/esp ... guide.html
if have any suggestion, please inform me. Thanks for your help.
B.R.
Postby Sprite » Wed Dec 22, 2021 9:08 am
Ah, so you're using ESP-IDF? What happens if you flash using 'idf.py flash'? After you flash, can you run 'idf.py monitor' and see what output you get?
turing_chang
Postby turing_chang » Thu Dec 23, 2021 1:42 pm
Hi
Thanks for your help, i already got the message of printf from uart port, so the program is fine.
B.R.
Users browsing this forum: Qwantbot, trendictionbot and 3 guests
