Hi everyone
I was using the esp32 without any problems
But after being off for a while, I turned on the device via USB cable to the computer
I noticed that the esp32 had trouble running
This is how the esp32 starts as long as I hold down the EN button
And when I release the button, the device has no function and stops
I can not even transfer the written program to the device normally
In general, to start the device, you must hold the en key
How can I solve this problem?
To work normally
Run the ESP32 by holding the EN button
Re: Run the ESP32 by holding the EN button
Try adding an 10uF capacitor between the EN pin and ground.
The problem was not solved
I also added capacitor values
It still does not work after turning on the board
Hi, is there any updates to this issue?
I ran a program which initally the ESP32 was able to read the incoming continuous data via a smartphone bluetooth.
Then I must have done something (Cant remember) but now I cant read the incoming continuous data via smartphone bluetooth.
On top of this, when I disenabled bluetooth to check if data is incoming via teraterm no incoming continous data unless I hold down the EN button (Reset button) then the red led on the ESP32 flashes while incoming data is received. However, I cannot hook bluetooth in this method.
Any updates on this issues?
Users browsing this forum: Perplexity-User, PerplexityBot, PetalBot and 3 guests
