[SOLVED] Connection to website over HTTPS protocol
filo_gr
Postby filo_gr » Mon Jan 03, 2022 2:20 pm
I need to connect my esp32 to a website.
The protocol used is of the HTTPS type.
However I'm encountering problems on the connection to the website. In particular, to obtain the OK response from the website (code 200), I need to send an header.
One example I found doesn't use headers (https_request). Searching docs I see that headers are included through the esp_http_client_set_header() function.
So I think I need this code:
Code: Untitled.c Select all
#define MAX_HTTP_RECV_BUFFER 512
#define MAX_HTTP_OUTPUT_BUFFER 2048
/* Constants that aren't configurable in menuconfig */
#define WEB_PORT "443"
#define WEB_URL "https://put_a_website.com"
static const char *TAG = "example";
static void https(void)
esp_http_client_config_t config = {
.url = WEB_URL,
.transport_type = HTTP_TRANSPORT_OVER_SSL,
.cert_pem = esp_crt_bundle_attach,
esp_http_client_set_url(client, WEB_URL);
esp_http_client_set_header(client, "header1",
"header2");
esp_err_t err = esp_http_client_perform(client);
if (err == ESP_OK)
ESP_LOGI(TAG, "Status = %d, content_length = %d",
esp_http_client_get_status_code(client),
esp_http_client_get_content_length(client));
else
ESP_LOGE(TAG, "Error perform http request %s", esp_err_to_name(err));
esp_http_client_cleanup(client);
void app_main(void)
ESP_ERROR_CHECK( nvs_flash_init() );
/* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
* Read "Establishing Wi-Fi or Ethernet Connection" section in
* examples/protocols/README.md for more information about this function.
ESP_ERROR_CHECK(example_connect());
https();
Here I have a warning when I use .cert_pem = esp_crt_bundle_attach, because
initialization of  'const char *' from incompatible pointer type 'esp_err_t (*)(void *)' {aka 'int (*)(void *)'}
and returns a Guru Meditation Error if I run the code.
I saw this on one of the examples, I can't understand why I have this problem (I enabled the certificate bundle from menuconfig).
If I remove the line above, I run the code but this time I obtain the following output:
W (4726) wifi:<ba-add>idx:1 (ifx:0, 30:b5:c2:fe:36:60), tid:4, ssn:0, winSize:64
E (4756) esp-tls-mbedtls: No server verification option set in esp_tls_cfg_t structure. Check esp_tls API reference
E (4756) esp-tls-mbedtls: Failed to set client configurations
E (4766) esp-tls: create_ssl_handle failed
E (4766) esp-tls: Failed to open new connection
E (4776) TRANS_SSL: Failed to open a new connection
E (4776) HTTP_CLIENT: Connection failed, sock < 0
E (4786) example: Error perform http request ESP_ERR_HTTP_CONNECT
How could I solve the problem? I'm not able to understand what's the wrong step...
Filippo
Re: Connection to website over HTTPS protocol
Postby Sprite » Tue Jan 04, 2022 1:24 am
The .cert_pem member is a pointer to a cert, not a callback. What you want is .crt_bundle_attach=esp_crt_bundle_attach instead.
filo_gr
Postby filo_gr » Tue Jan 04, 2022 7:05 am
Ok, but this is possible using another struct and other instructinos:
Code: Untitled.cpp Select all
esp_tls_cfg_t cfg = {
.crt_bundle_attach = esp_crt_bundle_attach,
struct esp_tls *tls = esp_tls_conn_http_new(web_urls[i], &cfg);
I mean, is it convenient to create the esp_http_client_config_t instead of esp_tls_cfg_t ?
Can they work toghether, or should I use only one of the two structs?
Filippo
filo_gr
Postby filo_gr » Tue Jan 04, 2022 7:15 am
Also, as mentioned above, inside the esp_http_client example, there is the following function:
static void https_with_url(void)
.url = "https://www.howsmyssl.com",
.event_handler = _http_event_handler,
if (err == ESP_OK) {
ESP_LOGI(TAG, "HTTPS Status = %d, content_length = %d",
Indeed I see .crt_bundle_attach = esp_crt_bundle_attach, reported as an error from the compiler.
Filippo
Postby Sprite » Tue Jan 04, 2022 7:21 am
As far as I checked, the esp_http_client should accept that parameter... are you sure you're not using an example from a newer esp-idf against an older esp-idf version?
filo_gr
Postby filo_gr » Tue Jan 04, 2022 7:29 am
I think my example corresponds to the Espressif's example on Github https://github.com/espressif/esp-idf/bl ... _example.c
I use ESP-IDF v4.3. Inside the example I see:
Picture of what I see.
The error when I compile is:
../main/esp_http_client_example.c: In function 'https_with_url':
../main/esp_http_client_example.c:375:10: error: 'esp_http_client_config_t' {aka 'struct <anonymous>'} has no member named 'crt_bundle_attach'
../main/esp_http_client_example.c:375:30: error: incompatible types when initializing type 'enum <anonymous>' using type 'esp_err_t (*)(void *)' {aka 'int (*)(void *)'}
Filippo
filo_gr
Postby filo_gr » Tue Jan 04, 2022 3:16 pm
Solution not found yet.
I only saw that if I use a specific certificate all works well. However I should use the bundle to test if it works anyway.
Filippo
Postby Sprite » Wed Jan 05, 2022 12:59 am
That confirms that then: you're looking at the example in the master branch. The 4.3 example does not have that, which indicates this is probably added after v4.3. If you're good with only one certificate, you can indeed follow that example.
filo_gr
Postby filo_gr » Wed Jan 05, 2022 1:48 pm
Thank you! Hence I understand we have to wait for the stable release if we want these features (or we should checkout to master branch).
Filippo
filo_gr
Postby filo_gr » Fri Feb 04, 2022 4:24 pm
I can't understand how could I connect my ESP32 to a website for which I don't own the SSL certificate (to check the signature).
Is it possible or it will be implemented in a next release?
Filippo
Users browsing this forum: Bytespider, PetalBot, Qwantbot and 1 guest
