How to use a "Standalone" html page for this example (ESP32 Arduino)
Pyshco
Postby Pyshco » Tue Jul 25, 2017 1:29 pm
The thing is... I need to know if is possible to connect a html file to this example, cause is horrible to work like this, can you guys help me?
#include <WiFi.h>
const char* ssid     = "CLAROQNK37";
const char* password = "9j98g4NuEaq496Yk";
WiFiServer server(80);
void setup()
    pinMode(5, OUTPUT);      // set the LED pin mode
    pinMode(4, OUTPUT);
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED)
        delay(100);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
    server.begin();
int value = 0;
void loop()
 WiFiClient client = server.available();   // listen for incoming clients
  if (client)                                // if you get a client,
    Serial.println("New Client.");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected())              // loop while the client's connected
      if (client.available())               // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n')                      // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0)
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("<head><title>Test Led http protocol</title></head>");
            client.print("<center><h1><b>ESP32 Web Control!!</b></h1></center>");
            client.print("<center><p><b>GREEN LED</b><a href=\"ON1\"><button>ON</button></a>&nbsp;<a href=\"OFF1\"><button>OFF</button></a></p></center>");
            client.print("<center><p><b>Yellow LED</b><a href=\"ON2\"><button>ON</button></a>&nbsp;<a href=\"OFF2\"><button>OFF</button></a></p></center>");
            client.print("<center><h1>Effects!!!!</h1></center>");
            client.print("<center><p>Blink<b>(2 Secs Aprox)</b><a href=\"BLINK\"><button>ON</button></center>");
            client.print("<center><p>Wave<b>(2 Secs Aprox)</b><a href=\"WAVE\"><button>ON</button></center>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          else
          {    // if you got a newline, then clear currentLine:
            currentLine = "";
        else if (c != '\r') // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /ON" or "GET /OFF":
        if (currentLine.endsWith("GET /ON1"))
          digitalWrite(5, HIGH);// GET /ON turns the LED on
        if (currentLine.endsWith("GET /OFF1"))
          digitalWrite(5, LOW);// GET /OFF turns the LED off
        if (currentLine.endsWith("GET /ON2"))
          digitalWrite(4, HIGH);// GET /ON turns the LED on
        if (currentLine.endsWith("GET /OFF2"))
          digitalWrite(4, LOW);// GET /OFF turns the LED off
        if (currentLine.endsWith("GET /BLINK"))
          delay(500);
          delay(500);
          delay(500);
          delay(500);
        if (currentLine.endsWith("GET /WAVE"))
          delay(500);
          delay(500);
          delay(500);
          delay(500);
    // close the connection:
    client.stop();
    Serial.println("Client Disconnected.");
tele_player
Re: How to use a "Standalone" html page for this example (ESP32 Arduino)
Postby tele_player » Wed Jul 26, 2017 5:05 am
Yes, you can serve HTML files. Of course, you'll need to learn how to use the file system, and how to handle file operations like create,read,write,etc.
There's a lot to learn, and you won't learn it all by asking on forums. School is good, and books. Probably easier to start with a real OS, Raspberry Pi Zero W is awesome, and almost as cheap as ESP32.
Pyshco
Postby Pyshco » Wed Jul 26, 2017 9:26 pm
Seems hard to learn but i will do my best!, thanks a lot!
f.h-f.s.
Postby f.h-f.s. » Thu Jul 27, 2017 1:13 pm
You can also try Mongoose OS or MicroPython which simplify this process.
Pyshco
Postby Pyshco » Thu Jul 27, 2017 7:20 pm
I WILL!!!!
bbx10node
Postby bbx10node » Fri Jul 28, 2017 3:30 am
C++ raw string literals can be used to embed HTML in a string constant without the annoying backslashes.
const char INDEX_HTML[] = R"======(
HTTP/1.1 200 OK
<html>
<body>
  <center><p><b>GREEN LED</b><a href="ON1"><button>ON</button></a>&nbsp;<a href="OFF1"><button>OFF</button></a></p></center>
  <center><p><b>Yellow LED</b><a href="ON2"><button>ON</button></a>&nbsp;<a href="OFF2"><button>OFF</button></a></p></center>
  <center><p>Blink<b>(2 Secs Aprox)</b><a href="BLINK"><button>ON</button></center>
  <center><p>Wave<b>(2 Secs Aprox)</b><a href="WAVE"><button>ON</button></center>
</body>
</html>
client.write(INDEX.HTML);
Users browsing this forum: Bing [Bot], Qwantbot and 2 guests
