The serial TX path seems to be down [custom board]
gfurtadoalmeida
Postby gfurtadoalmeida » Wed Jan 12, 2022 12:32 am
I've designed a custom ESP32 board based on WROOM-32 module for home applications.
However, I am not able to flash it. The board can send data through UART (as shown below) but cannot receive the flash data.
When trying to flash, I get the following error:
Download mode successfully detected, but getting no sync reply: The serial TX path seems to be down.
The USB connection was copied from the esp32_devkitc_v4.
What could be wrong?
ESP-IDF version: ESP-IDF v4.4-dev-3235-g3e370c4296-dirty
Data sent by the board
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:3480
load:0x40078000,len:7804
ho 0 tail 12 room 4
load:0x40080000,len:252
entry 0x40080034
<ESC>[0;32mI (46) boot: ESP-IDF v2.0-3-gbef9896 2nd stage bootloader<ESC>[0m
<ESC>[0;32mI (47) boot: compile time 05:59:45<ESC>[0m
<ESC>[0;32mI (47) boot: Enabling RNG early entropy source...<ESC>[0m
<ESC>[0;32mI (66) boot: SPI Speed      : 40MHz<ESC>[0m
<ESC>[0;32mI (78) boot: SPI Mode       : DIO<ESC>[0m
<ESC>[0;32mI (91) boot: SPI Flash Size : 4MB<ESC>[0m
<ESC>[0;32mI (103) boot: Partition Table:<ESC>[0m
<ESC>[0;32mI (114) boot: ## Label            Usage          Type ST Offset   Length<ESC>[0m
<ESC>[0;32mI (137) boot:  0 phy_init         RF data          01 01 0000f000 00001000<ESC>[0m
<ESC>[0;32mI (160) boot:  1 otadata          OTA data         01 00 00010000 00002000<ESC>[0m
<ESC>[0;32mI (183) boot:  2 nvs              WiFi data        01 02 00012000 0000e000<ESC>[0m
<ESC>[0;32mI (207) boot:  3 at_customize     unknown          40 00 00020000 000e0000<ESC>[0m
<ESC>[0;32mI (230) boot:  4 ota_0            OTA app          00 10 00100000 00180000<ESC>[0m
<ESC>[0;32mI (253) boot:  5 ota_1            OTA app          00 11 00280000 00180000<ESC>[0m
<ESC>[0;32mI (277) boot: End of partition table<ESC>[0m
<ESC>[0;32mI (290) boot: Disabling RNG early entropy source...<ESC>[0m
<ESC>[0;32mI (307) boot: Loading app partition at offset 00100000<ESC>[0m
<ESC>[0;32mI (1482) boot: segment 0: paddr=0x00100018 vaddr=0x00000000 size=0x0ffe8 ( 65512) <ESC>[0m
<ESC>[0;32mI (1483) boot: segment 1: paddr=0x00110008 vaddr=0x3f400010 size=0x1c5f0 (116208) map<ESC>[0m
<ESC>[0;32mI (1499) boot: segment 2: paddr=0x0012c600 vaddr=0x3ffb0000 size=0x0215c (  8540) load<ESC>[0m
<ESC>[0;32mI (1529) boot: segment 3: paddr=0x0012e764 vaddr=0x40080000 size=0x00400 (  1024) load<ESC>[0m
<ESC>[0;32mI (1553) boot: segment 4: paddr=0x0012eb6c vaddr=0x40080400 size=0x1b028 (110632) load<ESC>[0m
<ESC>[0;32mI (1632) boot: segment 5: paddr=0x00149b9c vaddr=0x400c0000 size=0x00034 (    52) load<ESC>[0m
<ESC>[0;32mI (1633) boot: segment 6: paddr=0x00149bd8 vaddr=0x00000000 size=0x06430 ( 25648) <ESC>[0m
<ESC>[0;32mI (1649) boot: segment 7: paddr=0x00150010 vaddr=0x400d0018 size=0x7a56c (501100) map<ESC>[0m
<ESC>[0;32mI (1676) heap_alloc_caps: Initializing. RAM available for dynamic allocation:<ESC>[0m
<ESC>[0;32mI (1699) heap_alloc_caps: At 3FFBA6B8 len 00025948 (150 KiB): DRAM<ESC>[0m
<ESC>[0;32mI (1720) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM<ESC>[0m
<ESC>[0;32mI (1741) heap_alloc_caps: At 4009B428 len 00004BD8 (18 KiB): IRAM<ESC>[0m
<ESC>[0;32mI (1762) cpu_start: Pro cpu up.<ESC>[0m
<ESC>[0;32mI (1774) cpu_start: Single core mode<ESC>[0m
<ESC>[0;32mI (1787) cpu_start: Pro cpu start user code<ESC>[0m
<ESC>[0;32mI (1848) cpu_start: Starting scheduler on PRO CPU.<ESC>[0m
<ESC>[0;32mI (2017) uart: queue free spaces: 10<ESC>[0m
Bin version:0.10.0<CR>
I (2018) wifi: wifi firmware version: c604573
I (2018) wifi: config NVS flash: enabled
I (2019) wifi: config nano formating: disabled
I (2027) wifi: Init dynamic tx buffer num: 32
I (2028) wifi: wifi driver task: 3ffc4f34, prio:23, stack:3584
I (2033) wifi: Init static rx buffer num: 10
I (2037) wifi: Init dynamic rx buffer num: 0
I (2041) wifi: Init rx ampdu len mblock:7
I (2045) wifi: Init lldesc rx ampdu entry mblock:4
I (2050) wifi: wifi power manager task: 0x3ffca2dc prio: 21 stack: 2560
I (2056) wifi: wifi timer task: 3ffcb35c, prio:22, stack:3584
<ESC>[0;31mE (2061) phy_init: PHY data partition validated<ESC>[0m
<ESC>[0;32mI (2084) phy: phy_version: 329, Feb 22 2017, 15:58:07, 0, 0<ESC>[0m
I (2084) wifi: mode : softAP (7c:9e:bd:39:c6:c1)
I (2087) wifi: mode : sta (7c:9e:bd:39:c6:c0) + softAP (7c:9e:bd:39:c6:c1)
I (2091) wifi: mode : softAP (7c:9e:bd:39:c6:c1)
Re: The serial TX path seems to be down [custom board]
Postby Sprite » Wed Jan 12, 2022 1:10 am
Your schematic looks reasonable. Could it be that there is something wrong with the trace labeled CPU_RX0 in your schematic; could you double-check the solder joints and maybe even put an oscilloscope on that pad of the ESP32 module to see if it's active on that side?
EDIT: Also, I would make C34 larger; the datasheet advises 1uF, but you could even try 10uF.
gfurtadoalmeida
Postby gfurtadoalmeida » Sat Jan 15, 2022 8:49 pm
ESP_Sprite, indeed, the problem was the solder joints on the QFN package.
The project was changed to add the 1uF capacitor that you (and the datasheet) suggested.
Thank you very much!
Postby Sprite » Sun Jan 16, 2022 1:25 am
Glad you could make it work!
Users browsing this forum: Amazon [Bot], Baidu [Spider], GPTBot, PerplexityBot and 2 guests
