How to make a https Server Arduino-ESP32
Pyshco
Postby Pyshco » Wed Jul 26, 2017 3:35 pm
I already have a http server on my ESP32, now, i need to know how to transform that http into a https server + a little introduction to MQTT exactly for arduino-ESP32. Do i need "<PubSubClient.h>" ? if i need it, how can i use it on this code?
CODE HERE:
/*Using the ESP-WROOM-32*/
/*Auto-refresh bult into the page*/
#include <WiFi.h>
const char* ssid     = "CLAROQNK37";
const char* password = "9j98g4NuEaq496Yk";
WiFiServer server(80);
const int analogPin = 32;  // Analog input pin , ours is connected to YL-83
int sensorValue = 0;
//Analog ADC read
//4095 => 3.3
// ADC * 3.3 / 4095 = v
void setup()
    Serial.begin(115200);    // Baud Rate
    pinMode(5, OUTPUT);      // Green LED
    pinMode(4, OUTPUT);      // Yellow LED
    pinMode(12,OUTPUT);      // Buzzer
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED)
        delay(100);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
    server.begin();
int value = 0;
void loop()
 WiFiClient client = server.available();   // listen for incoming clients
  if (client)                                // if you get a client,
    Serial.println("New Client.");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected())              // loop while the client's connected
      if (client.available())               // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n')                      // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0)
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("<head><title>Test Led http protocol</title><meta http-equiv=\"refresh\" content=\"1\"></head>");
            client.print("<center><h1><b>ESP32 Web Control!!</b></h1></center>");
            client.print("<center><p><b>GREEN LED</b><a href=\"ON1\"><button>ON</button></a>&nbsp;<a href=\"OFF1\"><button>OFF</button></a></p></center>");
            client.print("<center><p><b>Yellow LED</b><a href=\"ON2\"><button>ON</button></a>&nbsp;<a href=\"OFF2\"><button>OFF</button></a></p></center>");
            client.print("<center><h1>Effects!!!!</h1></center>");
            client.print("<center><p>Blink<b>(2 Secs Aprox)</b><a href=\"BLINK\"><button>ON</button></center>");
            client.print("<center><p>Wave<b>(2 Secs Aprox)</b><a href=\"WAVE\"><button>ON</button></center>");
            client.print("<center><h1>Buzzer!!1</h1></center>");
            client.print("<center><p>lil bip!<b>(1 Sec)</b><a href=\"BIP\"><button>ON</button></center>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          else
          {    // if you got a newline, then clear currentLine:
            currentLine = "";
        else if (c != '\r') // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /ON" or "GET /OFF":
        if (currentLine.endsWith("GET /ON1"))
          digitalWrite(5, HIGH);// GET /ON turns the LED on
        if (currentLine.endsWith("GET /OFF1"))
          digitalWrite(5, LOW);// GET /OFF turns the LED off
        if (currentLine.endsWith("GET /ON2"))
          digitalWrite(4, HIGH);// GET /ON turns the LED on
        if (currentLine.endsWith("GET /OFF2"))
          digitalWrite(4, LOW);// GET /OFF turns the LED off
        if (currentLine.endsWith("GET /BLINK"))
          delay(500);
          delay(500);
          delay(500);
          delay(500);
        if (currentLine.endsWith("GET /WAVE"))
          delay(500);
          delay(500);
          delay(500);
          delay(500);
        if (currentLine.endsWith("GET /BIP"))
          digitalWrite(12, HIGH);
          delay(1000);
          digitalWrite(12, LOW);
          delay(10);
          delay(500);
-SensorValue stuff
    sensorValue = analogRead(analogPin);
    double vol = sensorValue * 3.3 / 4095;
    //client.read(sensorValue);
    //client.read(vol);
    Serial.println(sensorValue);
    Serial.println(vol);
    client.print("<p>==================================================</p>");
    client.print("<center><p>Showing Actual Voltage(Constant)</p></center>");
    delay(1000);
    if (vol <= 2.00)
      delay(600);
    client.print("<p>=====Sensor Value=====</p>");
    client.print(sensorValue);
    client.print("<p>=====Actual Voltage=====</p>");
    client.print(vol);
-SensorValue stuff
    // close the connection:
    //client.stop();
    Serial.println("Client Disconnected.");
