Signature verify seems SLOW with ECDSA and mbedtls
jcolebaker
Postby jcolebaker » Wed Jan 19, 2022 1:42 am
We're using ECDSA signing with public keys to verify data received over BLE.
I use a SHA256 hash of the data, giving a hash size of 32 bytes. The signature is 70-73 bytes.
After setting up a context and loading the public key (which is all reasonably fast), I am calling "mbedtls_ecdsa_read_signature" to verify the signature (against the calculated hash and public key).
The mbedtls_ecdsa_read_signature call takes about 900 mS to complete. This is problematic because it makes the device slow to respond to commands (the data being verified).
ESP32 at 160 MHz. I got a moderate speed increase (~20%) when I configured the ESP32 for 240 MHz.
Is taking ~900ms to run mbedtls_ecdsa_read_signature normal / expected?
Any way I can speed it up?
Mahavir
Re: Signature verify seems SLOW with ECDSA and mbedtls
Postby Mahavir » Fri Feb 11, 2022 1:20 pm
This number looks to be on higher side. On similar test code, I got roughly ~390ms in default configuration. If we disable `CONFIG_MBEDTLS_HARDWARE_MPI`, then it can help improve this number to roughly ~240ms. You may find reasoning for this as discussed in https://github.com/espressif/esp-idf/issues/1177.
Additionally, you may also try to enable compiler optimisation level to performance (-O2), I was able to get ~28% improvement with this. Other performance tuning knobs are documented at https://docs.espressif.com/projects/esp ... rall-speed
I am attaching my test code here, you will to invoke `test_ecdsa()` from your application.
test_ecdsa.c
(7.93 KiB) Downloaded 438 times
Please feel free to share your feedback or any additional questions on this.
Thanks.
jcolebaker
Postby jcolebaker » Wed Mar 09, 2022 7:44 pm
I didn't see any significant change in performance by changing optimization levels. I didn't try changing MPI acceleration settings. However, I was able to get a huge increase in performance by using the "micro-ecc" library instead of mbedtls:
https://github.com/kmackay/micro-ecc
This library is around 5 x faster than mbedtls for ECDSA signature verification! This made it fast enough for our usage.
boulevard
Postby boulevard » Fri Apr 28, 2023 6:22 am
Hi there, I'm using ECDSA in MbedTLS on my esp32, and it is very slow too. I use curve P-256(also known as secp256r1), enable compiler optimisation level to performance (-O2), set the CPU frequency to 240MHz, but it still needs approximately 2s to verify the signature. Can you tell me what elliptic curve you use(such as secp256k1, secp256r1, ...) ?
Also, I'm so intereted in the micro-ecc library you mentioned above. Seems it doesn't have any instruction for using it on ESP32, and I'm a noob on esp32 programming, so can you teach me how to use it on ESP32?
Sincerely appreciate it!
Users browsing this forum: Bing [Bot], Semrush [Bot] and 0 guests
