RSA - The public key operation failed - ISSUE
doyoon.kim
Postby doyoon.kim » Fri Jan 21, 2022 1:39 am
Hi Team
We are developing a device that uses the ESP32 wrover to collect values ​​through environmental sensors and send them to AWS.
Sending to AWS " [E][ssl_client.cpp:36] _handle_error(): [start_ssl_client():218]: (-17040) RSA - The public key operation failed : BIGNUM - Memory allocation failed " is an issue and ESP32 reboot is occurring.
Please share if you have a solution to the issue.
issue debug
  • [D][HTTPClient.cpp:579] sendRequest(): request type: 'POST' redirCount: 0
    [V][WiFiClientSecure.cpp:127] connect(): PL_start_ssl_client with CA_cert
    [V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 58648
    [V][ssl_client.cpp:65] start_ssl_client(): Starting socket
    [V][ssl_client.cpp:79] start_ssl_client(): PL_WiFiGenericClass::hostByName2(host = g0me4ec8f5.execute-api.ap-northeast-2.amazonaws.com, srv = 1073555948)
    [V][ssl_client.cpp:106] start_ssl_client(): Seeding the random number generator
    [V][ssl_client.cpp:115] start_ssl_client(): Setting up the SSL/TLS structure...
    [ssl_client.cpp:129] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
    [V][ssl_client.cpp:199] start_ssl_client(): Setting hostname for TLS session...
    [V][ssl_client.cpp:214] start_ssl_client(): Performing the SSL/TLS handshake...
    [E][WiFiClientSecure.cpp:134] connect(): PL_start_ssl_client: _use_insecure = 1
    [E][WiFiClientSecure.cpp:137] connect(): start_ssl_client: -17040
    [V][ssl_client.cpp:267] stop_ssl_socket(): Cleaning SSL connection.
    [D][HTTPClient.cpp:1118] connect(): failed connect to g0me4ec8f5.execute-api.ap-northeast-2.amazonaws.com:443
    [W][HTTPClient.cpp:1417] returnError(): error(-1): connection refused
    [HTTP]https.POST() nResponseCode = -1 (T?), u32T = 161
normal debug
    [V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 59296
    [V][ssl_client.cpp:235] start_ssl_client(): Verifying peer X.509 certificate...
    [V][ssl_client.cpp:244] start_ssl_client(): Certificate verified.
    [V][ssl_client.cpp:259] start_ssl_client(): Free internal heap after TLS 13880
    [D][HTTPClient.cpp:1125] connect(): connected to g0me4ec8f5.execute-api.ap-northeast-2.amazonaws.com:443
    [V][ssl_client.cpp:297] send_ssl_data(): Writing HTTP request with 200 bytes...
    [V][ssl_client.cpp:297] send_ssl_data(): Writing HTTP request with 1724 bytes...
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'HTTP/1.1 200 OK'
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Date: Thu, 20 Jan 2022 11:05:48 GMT'
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Content-Type: application/json'
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Content-Length: 0'
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Connection: keep-alive'
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amzn-RequestId: 565f8e73-6d3d-4aa9-8b79-c68eefba5ae9'
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amz-apigw-id: MPdB4FhQIE0FryA='
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'X-Amzn-Trace-Id: Root=1-61e9420a-68db2f69205470d8631fd945;Sampled=0'
    [V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: ''
    [D][HTTPClient.cpp:1257] handleHeaderResponse(): code: 200
    [D][HTTPClient.cpp:603] sendRequest(): sendRequest code=200
    [HTTP]https.POST() nResponseCode = 200 (), u32T = 5617
Thank you ~~
Re: RSA - The public key operation failed - ISSUE
Postby Sprite » Fri Jan 21, 2022 2:28 am
That's an error that seems pretty clear to me - you ran out of memory. Suggest you reduce the RAM usage of your sketch.
doyoon.kim
Postby doyoon.kim » Fri Jan 21, 2022 5:16 am
Hi ESP_Sprite
This is a problem that occurs while operating normally. (more than 5 hours continuous time)
It is not a problem that occurs immediately after booting.
I found a similar issue while browsing the website, and couldn't find a solution there, so I raised the issue.
I need an answer that will solve the issue.
https://github.com/espressif/esp-idf/issues/222
Thank you
Postby Sprite » Fri Jan 21, 2022 8:02 am
...so what are you trying to say? Both the Arduino stack as well as the MbedTLS stack are capable of doing dynamic memory allocation, there's no reason at all why you should see an error directly after startup.
If you think there is a memory leak, I'd suggest logging the output of xPortGetFreeHeapSize() periodically over those 5 hours, see if that goes down consistently.
doyoon.kim
Postby doyoon.kim » Sun Jan 23, 2022 6:13 am
Hi ESP_Sprite
I conducted a data transfer test every 5 minutes to determine the cause of the problem.
As in the attached code source, I skipped verification of SSL
I need an answer to this part of why I am suddenly doing SSL authentication
WiFiClientSecure *pClientSecure = new WiFiClientSecure;
   https.addHeader(F("Content-Type"), F("application/json"));
   if (https.begin(*pClientSecure, pAQ_SERVER) != true)
      delete pClientSecure;
      pClientSecure = NULL;
      return -3;
  pClientSecure->setInsecure(); //skip verification
   feedWatchDog(true);
   int nRst = https.POST(pData, u16Size);
   pClientSecure->flush();
   pClientSecure->clearWriteError();
If you look at the source code I provided you are skipping the security related stuff.
It is part of the overall log of the test results.
<showSensorPacket()> stCount.u8SensorCount = 1
[20220121-114547:218] [APDS] 	      10 	       9 	      10 	      26 	       0
[POST] Count = 0, Length = 1736
[V][HTTPClient.cpp:245] beginInternal(): url: https://g5me8ec8e8.execute-api.ap-northeast-2.amazonaws.com/device/data
[D][HTTPClient.cpp:293] beginInternal(): protocol: https, host: g5me8ec8e8.execute-api.ap-northeast-2.amazonaws.com port: 443 url: /device/data
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 61428
[V][ssl_client.cpp:104] start_ssl_client(): Seeding the random number generator
[V][ssl_client.cpp:113] start_ssl_client(): Setting up the SSL/TLS structure...
[I][ssl_client.cpp:127] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
[V][ssl_client.cpp:197] start_ssl_client(): Setting hostname for TLS session...
[V][ssl_client.cpp:212] start_ssl_client(): Performing the SSL/TLS handshake...
[V][ssl_client.cpp:233] start_ssl_client(): Verifying peer X.509 certificate...
[V][ssl_client.cpp:242] start_ssl_client(): Certificate verified.
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 16028
[D][HTTPClient.cpp:1125] connect():  connected to g5me8ec8e8.execute-api.ap-northeast-2.amazonaws.com:443
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 200 bytes...
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 1736 bytes...
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Date: Fri, 21 Jan 2022 02:50:50 GMT'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Content-Length: 1668'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amzn-RequestId: 111e7f20-4c6b-4620-ab2c-8f1f864e2aec'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amz-apigw-id: MRndjHsTIE0FeOw='
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'X-Amzn-Trace-Id: Root=1-61ea1f88-11f0e9c32edc843423c9a09b;Sampled=0'
[D][HTTPClient.cpp:1260] handleHeaderResponse(): size: 1668
[HTTP]https.POST() nResponseCode = 200 (), u32T = 3018
[V][ssl_client.cpp:265] stop_ssl_socket(): Cleaning SSL connection.
[D][HTTPClient.cpp:400] disconnect(): tcp is closed
[20220121-115117:223] [APDS] 	      10 	      10 	      11 	      27 	       0
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 61108
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 14000
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Date: Fri, 21 Jan 2022 02:56:20 GMT'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amzn-RequestId: 3c90e669-607a-4a5e-815e-142bfd72b1be'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amz-apigw-id: MRoRHERBIE0FnOg='
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'X-Amzn-Trace-Id: Root=1-61ea20d2-48ff15d5276501b37b980130;Sampled=0'
[HTTP]https.POST() nResponseCode = 200 (), u32T = 3052
[20220121-115647:208] [APDS] 	      10 	      10 	      11 	      27 	       0
[POST] Count = 0, Length = 1738
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 60788
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 15380
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 1738 bytes...
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Date: Fri, 21 Jan 2022 03:01:48 GMT'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amzn-RequestId: 09d11f49-4539-4a24-8c7a-9f3c98eeff90'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amz-apigw-id: MRpEeGeroE0FeOw='
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'X-Amzn-Trace-Id: Root=1-61ea221c-0133a2132ad84adb27bd0700;Sampled=0'
[HTTP]https.POST() nResponseCode = 200 (), u32T = 1655
[20220121-120217:209] [APDS] 	      10 	      10 	      11 	      28 	       0
[POST] Count = 0, Length = 1737
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 60468
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 15068
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 1737 bytes...
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'Date: Fri, 21 Jan 2022 03:07:20 GMT'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amzn-RequestId: 5e4dfc30-3b02-49d9-8107-0b9ac3508c33'
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'x-amz-apigw-id: MRp4PHA9IE0FvuQ='
[V][HTTPClient.cpp:1216] handleHeaderResponse(): RX: 'X-Amzn-Trace-Id: Root=1-61ea2366-0de62cde0644a1012bbcb558;Sampled=0'
[HTTP]https.POST() nResponseCode = 200 (), u32T = 3023
[20220121-120747:206] [APDS] 	      11 	      10 	      11 	      28 	       0
[POST] Count = 0, Length = 1733
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 60148
[E][ssl_client.cpp:36] _handle_error(): [start_ssl_client():216]: (-17040) RSA - The public key operation failed : BIGNUM - Memory allocation failed
[E][WiFiClientSecure.cpp:133] connect(): start_ssl_client: -17040
[D][HTTPClient.cpp:1118] connect(): failed connect to g5me8ec8e8.execute-api.ap-northeast-2.amazonaws.com:443
[HTTP]https.POST() nResponseCode = -1 (4-?), u32T = 142
[HTTP]<Error> Correct? UDID=PAQ-TEST-002, WIFI_SSID=PAQ2.4G_Dev, WIFI_PW=8765022088
[20220121-121317:208] [APDS] 	      11 	      11 	      12 	      29 	       0
[POST] Count = 0, Length = 1717
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 59828
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 14428
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 1717 bytes...
[D][HTTPClient.cpp:603] sendRequest(): sendRequest code=-11
[W][HTTPClient.cpp:1417] returnError(): error(-11): read Timeout
[D][HTTPClient.cpp:1419] returnError(): tcp stop
[HTTP]https.POST() nResponseCode = -11 (P如?), u32T = 9542
[HTTP]<Error> httpsResponseCode = -11
[20220121-121847:208] [APDS] 	      12 	      11 	      12 	      30 	       0
[POST] Count = 0, Length = 1747
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 59500
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 14100
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 1747 bytes...
[HTTP]https.POST() nResponseCode = -11 (8??), u32T = 9789
[20220121-122417:205] [APDS] 	      12 	      11 	      13 	      32 	       0
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 59176
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 13776
[HTTP]https.POST() nResponseCode = -11 (瓢?), u32T = 10334
Normal operation time
The setlnsecure function works normally and the data is delivered to AWS.
Time of issue
Users browsing this forum: Barkrowler, ChatGPT-User and 3 guests
