esp32 cam with fingerprint reader
Posted: Sun Jan 23, 2022 2:58 pm
by stino18
I am still fairly new to working with an esp32 cam and I have a question. Hopefully someone can help me.
I would like to connect my fingerprint reader to my esp32 cam and also use the adafruit fingerprint library. I just don't know which pins to use and how to indicate this in the arduino sketch. can someone help me with this?
Re: esp32 cam with fingerprint reader
Posted: Mon Jan 24, 2022 6:32 am
by LJH
Which interface do you use? UART? SPI? I2C?
You could refer to 4.2 Peripheral Pin Configurations in ESP32 Datasheet and see which pins you should use.
Posted: Mon Jan 24, 2022 7:33 am
by alanesq
The available pins are very limited on the esp32cam, my best understanding is:
If using the sd card (must be in 1-bit mode) the main io pins available for general use are 13 and 12 (12 must not be high at boot),
14, 2 & 15 should also be available if you are not using the SD Card.
You can also use pins 1 and 3 if you do not use Serial (looks like they are restricted to one being input only and the other output only?)
Pin 4 is the onboard flash LED which you could possibly remove and use this pin for output (it is via a transistor) but again sd card needs to be in 1-bit mode if you are using it otherwise the sd-card uses pin 4. pin 33 is another onboard led which could possibly be used?
BTW - I have a sketch (Arduino) where I try to implement everything I discover about using them which may be of interest: https://github.com/alanesq/esp32cam-demo
Looks like some good info here: https://github.com/raphaelbs/esp32-cam- ... p32-cam.md
Posted: Thu Jan 27, 2022 12:32 pm
by stino18
Thank you for your answers.
If i want to use pin 12 and 13 for communication with the sensor, what do i need to change in the code so i can use these pins?
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Posted: Tue Mar 21, 2023 6:07 am
by franckNK
I finally found a way to use your fingerprint sensor using this library : Adafruit_Fingerprint.h
I tried this :
#include <HardwareSerial.h>
HardwareSerial mySerial(0);
I solved it with this code. :D :D
and the rest of the code is the same.
I was working on my smartdoorbell project and i wanted to integrate a fingerprint unlock based on face recognition.
Thanks, you helped me so much.
Franck NA - Madar
Posted: Mon Apr 03, 2023 7:42 pm
by vaibhavadsare
will you please contact me as soon as possible its very important for me as well. I am also working on this Project since last 3 months vaibhavadsare3333@gmail.com
