Getting song metadata with AVRCP commands (classic bluetooth)
Posted: Fri Jul 28, 2017 5:42 pm
by Sinisa_PUF
Hi.
I'm trying to get song metadata (title, album, artist, etc..) from the android phone connected to ESP32 via bluetooth.
Phone supports this feature, I tested it on raspberry pi.
I've compiled a2dp example code and got the phone to connect and stream music.
Then I used provided esp_avrc_ct_send_passthrough_cmd() function to send media button presses and that
is also working fine. I can see that media player on the phone responds to those commands.
esp-idf doesn't yet supports fetching metadata from target devices so I dug around to see how esp_avrc_ct_send_passthrough_cmd()
actually transfers passthrough commands. It has some hoops but ultimately it led me to BTA_AvRemoteCmd() in bt_av_api.c.
To confirm that this is the right function I constructed a new passthrough command and sent it with BTA_AvRemoteCmd().
Media player responded properly.
The same file (btw_av_api.c) contains BTA_AvMetaCmd() with the following comment: "Send a Metadata/Advanced Control command"
I had a bit of trouble constructing a proper message for the function since the documentation is very scarce but
I managed to find this volume setting code (line 1238) for android and ported it over. It doesn't work unfortunately.
I'm using a proper handle (btc_rc_vb.rc_handle). For transaction label I used 0x0, which should be ok since I don't have
consequtive messages.
Then I reconfigured it for metadata request (AVRC_PDU_GET_ITEM_ATTRIBUTES) but I still had no success.
There is also BTA_AvVendorCmd for sending vendor specific commands, which to my understanding can be used to
achieve the same effect since metadata is just a subset of vendor specific commands. It too doesn't't work.
I'm using Wireshark to capture packets on the smartphone side and I see AVRCP passthrough commands (play, pause, etc) but
no vendor specific commands (metadata) are ever received, not even a improperly formatted ones.
Am I missing something in the process? Feature mask from target (phone) says it supports vendor commands.
Re: Getting song metadata with AVRCP commands (classic bluetooth)
Posted: Sun Sep 17, 2017 8:03 pm
by Sinisa_PUF
Further investigation into this yielded no results unfortunately.
I'd certainly appreciate a nudge in the right direction.
Posted: Sat Sep 30, 2017 2:25 pm
by Sinisa_PUF
Some progress, finally. But still no cigar.
In this issue on github Karl Wang said:
I think the issue that you cannot get it working is that the feature bit "BTA_AV_FEAT_METADATA" is not set in the argument of function BTA_AvEnable, called in btc_avk.c.
which is correct. After uncommenting a line of code I was able to use BTA_AvMetaCmd() and I could see that it was executed.
But phone rejects the request because after a correct AVRCP header there are no parameters even though I set them.
Here is my code for sending metadata request:
static bt_status_t btc_avrc_ct_send_metadata_cmd()
  UINT32 attr_list[] = {
          AVRC_MEDIA_ATTR_ID_TITLE,
          AVRC_MEDIA_ATTR_ID_ARTIST,
          AVRC_MEDIA_ATTR_ID_ALBUM,
          AVRC_MEDIA_ATTR_ID_TRACK_NUM,
          AVRC_MEDIA_ATTR_ID_NUM_TRACKS,
          AVRC_MEDIA_ATTR_ID_GENRE,
          AVRC_MEDIA_ATTR_ID_PLAYING_TIME
  return get_element_attribute_cmd (AVRC_MAX_NUM_MEDIA_ATTR_ID, attr_list);
static bt_status_t get_element_attribute_cmd (uint8_t num_attribute, uint32_t *p_attr_ids)
    tAVRC_STS status = BT_STATUS_UNSUPPORTED;
    int count  = 0;
    tAVRC_COMMAND avrc_cmd = {0};
    BT_HDR *p_msg = NULL;
    bt_status_t tran_status;
    avrc_cmd.get_elem_attrs.opcode = AVRC_OP_VENDOR;
    avrc_cmd.get_elem_attrs.status = AVRC_STS_NO_ERROR;
    avrc_cmd.get_elem_attrs.num_attr = num_attribute;
    avrc_cmd.get_elem_attrs.pdu = AVRC_PDU_GET_ELEMENT_ATTR;
    for (count = 0; count < num_attribute; count++)
        avrc_cmd.get_elem_attrs.attrs[count] = p_attr_ids[count];
    status = AVRC_BldCommand(&avrc_cmd, &p_msg);
    if (status == AVRC_STS_NO_ERROR)
        BTA_AvMetaCmd(btc_rc_vb.rc_handle, 0, AVRC_CMD_STATUS, p_msg);
        status = BT_STATUS_SUCCESS;
    //if (p_msg != NULL) osi_freebuf(p_msg);
    return status;
I attached screenshots from Wireshark showing incomplete request, rejected response and
a proper message from a RN52 bluetooth module.
Posted: Sat Sep 30, 2017 4:54 pm
by WiFive
AVRC_BldCommand does not know how to build AVRC_PDU_GET_ELEMENT_ATTR
https://github.com/espressif/esp-idf/bl ... _ct.c#L212
Somebody did it here (backport I think) https://github.com/denisigo/fireprime_e ... 43d7c55b18
Posted: Sat Sep 30, 2017 10:48 pm
by Sinisa_PUF
Thank you :D
That's exactly what it was.
Just need to port/implement response handler and I'm set.
Posted: Tue Oct 03, 2017 3:16 am
by Sinisa_PUF
I've got it.
Thanks again WiFive.
Here's my commit.
There is still a few things I need to touch up but when i'm done I'll make a pull request.
Posted: Wed Sep 18, 2019 11:04 pm
by tr1p1ea
Sorry for the massive bump - I was wondering if anyone had any code examples for ESP32 BT Audio playback + AVRCP track information?
Posted: Sun Dec 08, 2019 1:21 pm
by Himbeer
This might help: https://github.com/espressif/esp-adf/issues/227
