UART Echo example in ESP IDF 4.0.1 with UART 1
Kampino
Postby Kampino » Sun Feb 06, 2022 5:14 pm
I use the UART Echo example with ESP IDF 4.0.1 and it looks like the software isn´t receiving anything when I use UART 1.
#include <stdio.h>
#include "freertos/task.h"
#include "driver/uart.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "esp_log.h"
static const char *TAG = "UART TEST";
#define INTERFACE UART_NUM_1
#define BUF_SIZE (1024)
static void echo_task(void *arg)
    uart_config_t uart_config = {
        .baud_rate = 115200,
        .parity    = UART_PARITY_DISABLE,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE
    int intr_alloc_flags = 0;
#if CONFIG_UART_ISR_IN_IRAM
    intr_alloc_flags = ESP_INTR_FLAG_IRAM;
#endif
    ESP_ERROR_CHECK(uart_driver_install(INTERFACE, BUF_SIZE * 2, 0, 0, NULL, intr_alloc_flags));
    ESP_ERROR_CHECK(uart_param_config(INTERFACE, &uart_config));
    ESP_ERROR_CHECK(uart_set_pin(INTERFACE, 5, 18, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
    char Message[] = "AA";
    uint8_t *data = (uint8_t *) malloc(BUF_SIZE);
    while(1)
        uart_write_bytes(INTERFACE, (const char*)Message, sizeof(Message));
        int len = uart_read_bytes(INTERFACE, data, (BUF_SIZE - 1), 20 / portTICK_RATE_MS);
        if(len)
            data[len] = '\0';
            ESP_LOGI(TAG, "Recv str: %s", (char *) data);
extern "C" void app_main(void)
    xTaskCreate(echo_task, "uart_echo_task", 2048, NULL, 10, NULL);
I have bridged pin 5 and 18 and the example works like a charm when I use ESP IDF version 4.3.1. How can I use this example with IDF 4.0.1? What is the bug here?
Thank you for help.
Jeevan
Re: UART Echo example in ESP IDF 4.0.1 with UART 1
Postby Jeevan » Tue Jul 19, 2022 11:07 am
May I ask how do you monitor the data sent by uart.
Also when writing to it, you use a serial monitor to e.g. Teraterm to write to the port connected to pons 5&18?
Users browsing this forum: Amazon [Bot], Applebot, Baidu [Spider], ChatGPT-User and 6 guests
