Esp-prog doesn't want to work anymore
Samuele
Postby Samuele » Mon Feb 07, 2022 4:20 pm
Hello guys
I work with esp32 and esp-prog jtag debugger on Visual Studio Code (1.64.0) and esp-idf (v1.3.0) for a few months without big problema ... but at the enad of dicember i no be able to go in debug mode with esp-prog, i was checked all pin on board and debugger, checked driver on windows (with zadig) and at the and i was install all on other pc, but the comunication not not works ...
I'm desperate enough to accept any suggestions
follow the comuniucation log
tahks in advance
Open On-Chip Debugger  v0.10.0-esp32-20210401 (2021-04-01-15:46)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
adapter speed: 20000 kHz
❌ Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : accepting 'tcl' connection on tcp/6666
Info : dropped 'tcl' connection
