Input-only pins?
bridger6649
Input-only pins?
Postby bridger6649 » Tue Feb 08, 2022 5:00 am
Many ESP32 related sites refer to GPIO pins 34-39 as "input-only", for example:
https://randomnerdtutorials.com/esp32-p ... nce-gpios/
GPIOs 34 to 39 are GPIs – input only pins. These pins don’t have internal
pull-up or pull-down resistors. They can’t be used as outputs, so use these
pins only as inputs:
GPIO 34
GPIO 35
GPIO 36
GPIO 39
However, the current datasheet for the ESP32-S2-WROVER indicates that those pins can be used as either input or output.
(Source: esp32-s2_datasheet_en.pdf)
Is this correct? Was there a restriction in earlier generations of the ESP32 chip?
I need to use those pins for output so hopefully the datasheet is correct!
Thanks!
Re: Input-only pins?
Postby Sprite » Tue Feb 08, 2022 6:54 am
Yes. The original ESP32 has these restrictions, the -S2 and later chips generally do not.
