esp_wifi_connect() working / nor working
jpquan
Postby jpquan » Wed Feb 09, 2022 12:10 pm
Hello! First I'd like to tell I started ESP32 very recently so please be kind with my issue / question ;)
I was trying to have one example of esp-idf-4.4 work, the one on Wifi / Get Started / Station, located here: esp-idf-v4.4/examples/wifi/getting_started/station
on a dev kit (ESP32-WROVER)
Full original example is the following:
/* WiFi station Example
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
/* The examples use WiFi configuration that you can set via project configuration menu
   If you'd rather not, just change the below entries to strings with
   the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID      CONFIG_ESP_WIFI_SSID
#define EXAMPLE_ESP_WIFI_PASS      CONFIG_ESP_WIFI_PASSWORD
#define EXAMPLE_ESP_MAXIMUM_RETRY  CONFIG_ESP_MAXIMUM_RETRY
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event, but we only care about two events:
 * - we are connected to the AP with an IP
 * - we failed to connect after the maximum amount of retries */
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT      BIT1
static const char *TAG = "wifi station";
static int s_retry_num = 0;
static void event_handler(void* arg, esp_event_base_t event_base,
                                int32_t event_id, void* event_data)
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
        if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
            esp_wifi_connect();
            s_retry_num++;
            ESP_LOGI(TAG, "retry to connect to the AP");
            xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
        ESP_LOGI(TAG,"connect to the AP fail");
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
        ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
        s_retry_num = 0;
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
void wifi_init_sta(void)
    s_wifi_event_group = xEventGroupCreate();
    esp_netif_create_default_wifi_sta();
    esp_event_handler_instance_t instance_any_id;
    esp_event_handler_instance_t instance_got_ip;
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
                                                        ESP_EVENT_ANY_ID,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_any_id));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
                                                        IP_EVENT_STA_GOT_IP,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_got_ip));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = EXAMPLE_ESP_WIFI_SSID,
            .password = EXAMPLE_ESP_WIFI_PASS,
            /* Setting a password implies station will connect to all security modes including WEP/WPA.
             * However these modes are deprecated and not advisable to be used. Incase your Access point
             * doesn't support WPA2, these mode can be enabled by commenting below line */
	     .threshold.authmode = WIFI_AUTH_WPA2_PSK,
            .pmf_cfg = {
                .capable = true,
                .required = false
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    /* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
     * number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
            WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
            pdFALSE,
            pdFALSE,
            portMAX_DELAY);
    /* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
     * happened. */
    if (bits & WIFI_CONNECTED_BIT) {
        ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
                 EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
    } else if (bits & WIFI_FAIL_BIT) {
        ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
        ESP_LOGE(TAG, "UNEXPECTED EVENT");
    /* The event will not be processed after unregister */
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
    vEventGroupDelete(s_wifi_event_group);
void app_main(void)
    //Initialize NVS
    ESP_ERROR_CHECK(ret);
    ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
    wifi_init_sta();
I use it under Eclipse 2021-06, using ESP-IDF plugin for Eclipse, and compiled as C++, not C.
I have a strange behavior that I cannot explain to myself, relating to this portion of the code (event handler):
        esp_wifi_connect();
            esp_wifi_connect();
            s_retry_num++;
        s_retry_num = 0;
If I let it as it is shown, Wifi connection does not happen in my case. Full log from console:
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6612
load:0x40078000,len:14780
load:0x40080400,len:3792
0x40080400: _init at ??:?
entry 0x40080694
I (27) boot: ESP-IDF v4.4-dirty 2nd stage bootloader
I (27) boot: compile time 07:52:46
I (27) boot: chip revision: 1
I (30) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (37) boot.esp32: SPI Speed      : 40MHz
I (42) boot.esp32: SPI Mode       : DIO
I (46) boot.esp32: SPI Flash Size : 2MB
I (51) boot: Enabling RNG early entropy source...
I (56) boot: Partition Table:
I (60) boot: ## Label            Usage          Type ST Offset   Length
I (67) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (74) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (82) boot:  2 factory          factory app      00 00 00010000 00100000
I (89) boot: End of partition table
I (94) boot_comm: chip revision: 1, min. application chip revision: 0
I (101) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=134a8h ( 79016) map
I (138) esp_image: segment 1: paddr=000234d0 vaddr=3ffb0000 size=03804h ( 14340) load
I (144) esp_image: segment 2: paddr=00026cdc vaddr=40080000 size=0933ch ( 37692) load
I (159) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=6d690h (448144) map
I (322) esp_image: segment 4: paddr=0009d6b8 vaddr=4008933c size=0afa8h ( 44968) load
I (341) esp_image: segment 5: paddr=000a8668 vaddr=50000000 size=00010h (    16) load
I (351) boot: Loaded app from partition at offset 0x10000
I (351) boot: Disabling RNG early entropy source...
I (363) cpu_start: Pro cpu up.
I (363) cpu_start: Starting app cpu, entry point is 0x40081174
0x40081174: call_start_cpu1 at /Dev/ESP32/esp-idf-eclipse/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156
I (0) cpu_start: App cpu up.
I (377) cpu_start: Pro cpu start user code
I (377) cpu_start: cpu freq: 160000000
I (377) cpu_start: Application information:
I (382) cpu_start: Project name:     Esp32Blink
I (387) cpu_start: App version:      1
I (391) cpu_start: Compile time:     Feb  9 2022 07:56:20
I (398) cpu_start: ELF file SHA256:  dde9b6e1dcbae094...
I (404) cpu_start: ESP-IDF:          v4.4-dirty
I (409) heap_init: Initializing. RAM available for dynamic allocation:
I (416) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (422) heap_init: At 3FFB74A8 len 00028B58 (162 KiB): DRAM
I (428) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (435) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (441) heap_init: At 400942E4 len 0000BD1C (47 KiB): IRAM
I (448) spi_flash: detected chip: gd
I (452) spi_flash: flash io: dio
W (455) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (470) cpu_start: Starting scheduler on PRO CPU.
I (563) wifi station: ESP_WIFI_MODE_STA
I (583) wifi:wifi driver task: 3ffc06cc, prio:23, stack:6656, core=0
I (583) system_api: Base MAC address is not set
I (583) system_api: read default base MAC address from EFUSE
I (613) wifi:wifi firmware version: 7679c42
I (613) wifi:wifi certification version: v7.0
I (613) wifi:config NVS flash: enabled
I (613) wifi:config nano formating: disabled
I (613) wifi:Init data frame dynamic rx buffer num: 32
I (613) wifi:Init management frame dynamic rx buffer num: 32
I (623) wifi:Init management short buffer num: 32
I (623) wifi:Init dynamic tx buffer num: 32
I (633) wifi:Init static rx buffer size: 1600
I (633) wifi:Init static rx buffer num: 10
I (643) wifi:Init dynamic rx buffer num: 32
I (643) wifi_init: rx ba win: 6
I (643) wifi_init: tcpip mbox: 32
I (653) wifi_init: udp mbox: 6
I (653) wifi_init: tcp mbox: 6
I (663) wifi_init: tcp tx win: 5744
I (663) wifi_init: tcp rx win: 5744
I (663) wifi_init: tcp mss: 1440
I (673) wifi_init: WiFi IRAM OP enabled
I (673) wifi_init: WiFi RX IRAM OP enabled
I (703) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (793) wifi:mode : sta (c8:c9:a3:d8:15:1c)
I (793) wifi:enable tsf
I (803) wifi station: wifi_init_sta finished.
I (2853) wifi station: retry to connect to the AP
I (2853) wifi station: connect to the AP fail
I (4903) wifi station: retry to connect to the AP
I (4903) wifi station: connect to the AP fail
I (6953) wifi station: retry to connect to the AP
I (6953) wifi station: connect to the AP fail
I (9003) wifi station: retry to connect to the AP
I (9003) wifi station: connect to the AP fail
I (11053) wifi station: retry to connect to the AP
I (11053) wifi station: connect to the AP fail
I (13103) wifi station: connect to the AP fail
I (13103) wifi station: Failed to connect to SSID:...
If I put a log, for instance
ESP_LOGI(TAG, "event_handler just processed event %s %d", event_base, event_id);
at the end of the handler, connection works. It works from the moment I put a ESP_LOGI call in the code of the handler, whatever the place. Full log shows the difference:
entry 0x40080694
I tried to set some delay before or after esp_wifi_connect() call using vTaskDelay but there is no change.
Any explanation or advice anybody?
jpquan
Re: esp_wifi_connect() working / nor working
Postby jpquan » Tue Feb 15, 2022 1:40 pm
Hello again! I did some investigations, and at last I could narrow down the issue.
First I got some additional information about the disconnected reason: added this line of code in the event_handler:
wifi_event_sta_disconnected_t *event = (wifi_event_sta_disconnected_t *) event_data;
and got reason 201, which means "AP_NOT_FOUND".
At connect there is a scan, and the scan cannot find my AP.
Then I implemented Wifi scans from the examples, and I could see that my AP was listed :shock: .
For the moment, I think this may be due to random values in memory when wifi_sta_config_t is created, so I carefully zeroed or set every possible value; here is my code (in C++):
    wifi_sta_config_t wifi_sta;
    for (int i=0; i<32; i++) {
    	wifi_sta.ssid[i] = 0;
    for (int i=0; i<64; i++) {
    	wifi_sta.password[i] = 0;
    memcpy(wifi_sta.ssid, EXAMPLE_ESP_WIFI_SSID, strlen(EXAMPLE_ESP_WIFI_SSID)+1);
    memcpy(wifi_sta.password, EXAMPLE_ESP_WIFI_PASS, strlen(EXAMPLE_ESP_WIFI_PASS)+1);
    wifi_sta.bssid_set = 0;
    wifi_sta.channel = 0;
    wifi_sta.scan_method = WIFI_FAST_SCAN;
    for(int i=0; i<6; i++) {
    	wifi_sta.bssid[i] = 0;
    wifi_pmf_config_t wifi_pmf;
    wifi_pmf.capable = true;
    wifi_pmf.required = false;
    wifi_sta.pmf_cfg = wifi_pmf;
    wifi_scan_threshold_t wifi_scan_threshold;
    wifi_scan_threshold.authmode = WIFI_AUTH_WPA_PSK;
    wifi_sta.threshold = wifi_scan_threshold;
    wifi_config_t wifi_config;
    wifi_config.sta = wifi_sta;
Now it seems to connect OK, but I still have to confirm that over time.
glrtheil
Postby glrtheil » Thu Feb 17, 2022 3:23 pm
Have you tried using the blufi example to configure and connect your device to wifi? I found it to be the best example of how to make wifi work properly, with the least amount of code.
Users browsing this forum: ChatGPT-User and 5 guests
