Thingsboard cloud MQTT
liamm36
Postby liamm36 » Wed Feb 09, 2022 4:05 pm
Hey,
Has anyone had any luck connecting to thingsboard cloud MQTT broker recently?
I've tried
    esp_mqtt_client_config_t mqtt_cfg = {
    			.client_id="TbDev",
			.password=mypassword,
			.username=myusername,
			.uri =  "mqtt://cloud.thingsboard.io",
			.port = 1883,
		//.username = mqtt_access_token
where password and username were from a device created on thingsboard.
I also tried using access tokens and following thingsboard example where the username is the token.
    const char *mqtt_url = get_mqtt_url(running_partition_label);
    const uint32_t mqtt_port = get_mqtt_port(running_partition_label);
    const char *mqtt_access_token = get_mqtt_access_token(running_partition_label);
        .uri = mqtt_url,
        .event_handle = mqtt_event_handler,
        .port = mqtt_port,
I've tried both the esp-idf MQTT tcp example and thingsboards own ota example (which still communicates via MQTT with their broker) https://github.com/thingsboard/esp32-ota. I have been using the master branch and thingsboard recommends ESP-IDF version 3.3. A few events were unhandled by the MQTT event handler which caused an initial build failure but adding them to the case switch statement built the project.
In both cases I get
"MQTT_CLIENT: Connection refused, not authorized"
Are there any other credentials required other than access token or username/pass for a device?
I can use thingsboard from the esp-32 in Arduino SDK. I can connect to other MQTT brokers in ESP-IDF but cannot seem to get thingsboard working.
