Problem with extension and terminal in Visual Studio
Posted: Thu Feb 10, 2022 3:57 pm
Hi, I try to start with ESP. I install tool from this tutorial https://www.youtube.com/watch?v=5IuZ-E8Tmhg and have two problems. I'm nevbie so please write like to stupid man.
1. VSC cannot download and install extension. I get info about XHR failed. I read that problem can be with my Proxy settings, I try to check this but without result. Here is log, maybe you have some idea?
2. Man in tutorial change terminal and add some command.
In VSC gigher like 1.59 they switch off this road. Fix is probably described here https://stackoverflow.com/questions/676 ... -in-vscode but I not understand what where I must past new code ;/
IDF IDE is 4.4, system is windows 7.
[2022-02-09 19:30:32.540] [renderer1] [info] IExtensionHostStarter.start() took 72 ms.
[2022-02-09 19:30:33.051] [renderer1] [error] [Extension Host] (node:8932) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(Use `Code --trace-deprecation ...` to show where the warning was created)
[2022-02-09 19:30:38.308] [renderer1] [error] XHR failed: Error: XHR failed
at XMLHttpRequest.E.onerror (vscode-file://vscode-app/c:/Program%20Files/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:83:27239)
[2022-02-09 19:38:31.041] [renderer1] [info] Settings Sync: Updated current session e2e1b609-5339-46dd-9780-6c9b031d0be3
[2022-02-09 19:38:44.958] [renderer1] [warning] Settings pattern "keyboard.*" doesn't match any settings
[2022-02-09 19:40:34.892] [renderer1] [error] XHR failed: Error: XHR failed
[2022-02-09 19:40:39.465] [renderer1] [error] Error: XHR failed
[2022-02-09 19:40:39.524] [renderer1] [error] XHR failed: Error: XHR failed
[2022-02-09 19:41:11.586] [renderer1] [error] XHR failed: Error: XHR failed
[2022-02-09 19:43:26.582] [renderer1] [error] XHR failed: Error: XHR failed
[2022-02-09 19:43:29.540] [renderer1] [error] XHR failed: Error: XHR failed
[2022-02-09 19:44:05.304] [renderer1] [warning] Settings pattern "keyboard.*" doesn't match any settings
[2022-02-09 19:44:17.369] [renderer1] [error] XHR failed: Error: XHR failed
[2022-02-09 19:47:10.842] [renderer1] [error] XHR failed: Error: XHR failed
[2022-02-09 19:47:14.233] [renderer1] [error] Error: XHR failed
[2022-02-09 19:47:14.298] [renderer1] [error] XHR failed: Error: XHR failed
at XMLHttpRequest.E.onerror (vscode-file://vscode-app/c:/Program%20Files/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:83:27239)2. Man in tutorial change terminal and add some command.
"folders": [
"path": "."
"settings":{
"terminal.integrated.shell.windows" : "cmd.exe",
"terminal.integrated.shellArgs.windows" : [
"/k",
"C:/esp/frameworks/esp-idf-v4.4/export.bat"
}IDF IDE is 4.4, system is windows 7.
