Base mac is shorter for one character
marware
Postby marware » Sat Feb 12, 2022 8:23 pm
Hi all,
Not sure if happens to anyone else, but one of my devices is reporting a shorter base mac address when converted to a string.
I feel the problem is with conversion, here is the code. Similar code is displayed in example so I'm confused :?
uint8_t mac[6];
    esp_err_t result;
    result = esp_efuse_mac_get_default(mac);
    if(result != ESP_OK)
        ESP_LOGE(TAG, "Failed to get mac address. Error code: '%d'", result);
        // TODO: restart device
    char deviceId[13];
    sprintf(deviceId,"%x%x%x%x%x%x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
the result is: 943cc6d8878
Have no idea what is happening.
Re: Base mac is shorter for one character
Postby Sprite » Sun Feb 13, 2022 7:38 am
Use '%02x' instead of '%x'.
marware
Postby marware » Sun Feb 13, 2022 2:49 pm
Yes, thanks, I've realized that as soon as I posted :P
The return value of the mac is of course valid and formating was missing 0 before the last character: 943cc6d88708
I would be willing to update example base_mac_address_example_main.c if it make sense to you?
Postby Sprite » Mon Feb 14, 2022 1:39 am
As far as I can see it, that example uses "0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x" as the notation, which also makes it clear which digit is which without the need for a leading zero.
Users browsing this forum: Baidu [Spider], ChatGPT-User and 8 guests
