Attempting installation of drivers on win10 ent x64 b19043 from offline installer fails with code -2. Log file is attached.
Perhaps there is a separate download somewhere for the drivers so I can troubleshoot in greater detail?
Thanks so much
Joe
Windows driver install fails with exit code -2
theycallmevirgo
- Setup Log 2022-02-15 #008.txt
- (36.49 KiB) Downloaded 493 times
Re: Windows driver install fails with exit code -2
Thank you for reporting the problem.
This is definitely bug. I've created an issue to resolve it: https://github.com/espressif/idf-installer/issues/113
The installer does not support just an installation of a single driver without ESP-IDF.
There are following workarounds:
Workaround 1:
run command idf-env.exe driver install --ftdi
details: https://github.com/espressif/idf-env#qu ... powershell
Workaround 2:
install driver manually: https://github.com/espressif/idf-instal ... of-drivers
Workaround 1:
Workaround 2:
- Juraj Michálek
Senior Embedded Software Engineer at Espressif Systems
theycallmevirgo
Just FYI, the issue occurs even if all other components are selected for installation.
Thank you for notification about the scenario. We will double-check this setup.
- Juraj Michálek
arjunguptaatx
I am getting the exact same error. Is there a stable version I can use?
Users browsing this forum: ChatGPT-User, Semrush [Bot] and 1 guest
