ESP32S2 - Quad SPI Slave / QPI Example + Notes
Posted: Thu Feb 17, 2022 9:08 pm
by KWolfe81
I went looking for an example of using the QuadSPI on the ESP32S2 in slave mode and couldn't find one. So I wrote one and am sharing it case anyone in the future goes down this road:
https://gitlab.com/kevinwolfe/esp32s2_qspi
All source code is in a single file: ./main/main.c
Test script included: ./tools/test_qspi.py (requires 'ft4222' lib, "pip install ft4222").
I am using an FT4222 development board in master to interact with the device. It's not a perfect example. First, I'm only doing DMA operations. Next, I could not get QuadSPI reads to work (e.g. master/host PC reads data from ESP32S2 slave device). Writes worked fine. My work-around is to only ever use QPI mode, which firmware automatically enters during SPI init. And lastly, I could only get QPI reads to work if I set the dummy bytes to 0xFF. No idea why that's the case, but it is what it is.
Good luck.
Re: ESP32S2 - Quad SPI Slave / QPI Example + Notes
Posted: Fri Oct 14, 2022 4:09 pm
by vsfred
Hello KWolfe81,
I would like to use Quad SPI in slave mode on my ESP32 S3. I'm interesting by your example. But your link is down, can you reload it ?
Posted: Tue Sep 19, 2023 3:09 pm
by natee.th
Hello KWolfe81, Me too Please.
Re: How to use the upper 4MB of ESP-Wrover 8MB PSRAM
Posted: Tue Sep 19, 2023 3:52 pm
by dallim30
I am using an ESP-Wrover-Kit.
It has a 16MB external SPI flash and an additional 8 MB PSRAM.
In the datasheet, it is mentioned that up to 4 MB of PSRAM can be mapped into CPU data memory space at a time.
As only 4 MB memory space is considered for External SRAM (0x3F80_0000 to 0x3FBF_FFFF), how can I use (map) the extra 4MB?
What would be the CPU data memory address to map that extra 4MB?
Is there an option to use part of the 4MB mappable addres srange to bank-switch the remaining memory in?
Do any one have a clue and similar situation for me to take a reference?
Thanks!
Posted: Wed Oct 29, 2025 10:23 am
by Vineethad
Hello @KWolfe81,
I am currently working with the ESP32-C6 device and need to configure it as a QSPI slave. I have reviewed the available examples but could not find any relevant implementation for QSPI slave mode.
Could you please share your example code or guidance that would help enable QSPI slave functionality on the ESP32-C6?
Thank you for your support.
Regards,
D. Vineetha
