wifi 校准失败导致复位
Posted: Sat Mar 05, 2022 2:42 pm
by lgpww123
esp32 s3 芯片,编译环境是idf4.3 每次开启复位“phy_init: failed to load RF calibration data (0xffffffff), falling back to full ”
如下log
[22:37:08.654]收←◆
[22:37:08.679]收←◆[0;32mI (233) esp_image: segment 4: paddr=000b46bc vaddr=40376448 size=0c5fch ( 50684) load[0m
[0;32mI (244) esp_image: segment 5: paddr=000c0cc0 vaddr=600fe000 size=00010h ( 16) load[0m
[0;32mI (250) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (251) boot: Disabling RNG early entropy source...[0m
[0;33mW (253) bootloader_random: RNG for ESP32-S3 not currently supported[0m
[0;32mI (271) cpu_start: Pro cpu up.[0m
[0;32mI (271) cpu_start: Starting app cpu, entry point is 0x4037505c[0m
[0;32mI (0) cpu_start: App cpu up.[0m
[0;32mI (285) cpu_start: Pro cpu start user code[0m
[0;32mI (285) cpu_start: cpu freq: 160000000[0m
[0;32mI (285) cpu_start: Application information:[0m
[0;32mI (288) cpu_start: Project name: mqtt_ssl[0m
[0;32mI (293) cpu_start: App version: 1[0m
[0;32mI (298) cpu_start: Compile time: Mar 5 2022 22:34:54[0m
[0;32mI (304) cpu_start: ELF file SHA256: 37284e84702eb7d1...[0m
[0;32mI (310) cpu_start: ESP-IDF: HEAD-HASH-NOTFOUND[0m
[0;32mI (316) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (323) heap_init: At 3FC9A2F8 len 00045D08 (279 KiB): D/IRAM[0m
[0;32mI (329) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM[0m
[0;32mI (336) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM[0m
[0;32mI (343) spi_flash: detected chip: gd[0m
[0;32mI (346) spi_flash: flash io: dio[0m
[0;33mW (350) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.[0m
[0;32mI (364) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (374) MQTTS_EXAMPLE: [APP] Startup..[0m
[0;32mI (374) MQTTS_EXAMPLE: [APP] Free memory: 356916 bytes[0m
[0;32mI (384) MQTTS_EXAMPLE: [APP] IDF version: HEAD-HASH-NOTFOUND[0m
[0;32mI (414) pp: pp rom version: e7ae62f[0m
[0;32mI (414) net80211: net80211 rom version: e7ae62f[0m
I (424) wifi:wifi driver task: 3fce569c, prio:23, stack:6656, core=0
[0;32mI (424) system_api: Base MAC address is not set[0m
[0;32mI (424) system_api: read default base MAC address from EFUSE[0m
I (444) wifi:wifi firmware version: 4c9ede1
I (444) wifi:wifi certification v
[22:37:08.895]收←◆ersion: v7.0
I (444) wifi:config NVS flash: enabled
I (444) wifi:config nano formating: disabled
I (454) wifi:Init data frame dynamic rx buffer num: 32
I (454) wifi:Init management frame dynamic rx buffer num: 32
I (464) wifi:Init management short buffer num: 32
I (464) wifi:Init dynamic tx buffer num: 32
I (464) wifi:Init static tx FG buffer num: 2
I (474) wifi:Init static rx buffer size: 1600
I (474) wifi:Init static rx buffer num: 10
I (484) wifi:Init dynamic rx buffer num: 32
[0;32mI (484) wifi_init: rx ba win: 6[0m
[0;32mI (484) wifi_init: tcpip mbox: 32[0m
[0;32mI (494) wifi_init: udp mbox: 6[0m
[0;32mI (494) wifi_init: tcp mbox: 6[0m
[0;32mI (504) wifi_init: tcp tx win: 5744[0m
[0;32mI (504) wifi_init: tcp rx win: 5744[0m
[0;32mI (504) wifi_init: tcp mss: 1440[0m
[0;32mI (514) wifi_init: WiFi IRAM OP enabled[0m
[0;32mI (514) wifi_init: WiFi RX IRAM OP enabled[0m
[0;32mI (524) example_connect: Connecting to lili...[0m
[0;32mI (524) phy_init: phy_version 100,24b028a,Jul 1 2021,14:17:09[0m
[0;33mW (534) phy_init: failed to load RF calibration data (0xffffffff), falling back to full ESP-ROM:esp32s3-20210327
[22:37:09.007]收←◆Build:Mar 27 2021
rst:0x13 (GLITCH_RTC_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x1580
load:0x403b6000,len:0x878
load:0x403ba000,len:0x2ae0
entry 0x403b61c0
Re: wifi 校准失败导致复位
Posted: Tue May 10, 2022 7:39 am
by LJY
esp32 s3 芯片,你需要使用 tag v4.4 及以上的版本
