WiFi Prov BLE Arduino Not Working for iOS Devices
maialbe2823
I am trying to provision via ble my esp32 board for the esp rainmaker app however its not popping up in the ble scanner of the rainmaker app or I if I do it via qr code it get the following error: No Bluetooth device found with given prefix. However; as I said this only happens when I try to use any iOS device as in android devices it works indeed. I don't know if its a library bug on arduino ide part or something. Also, whenever I run an example from esp-idf using the terminal it does work for iOS devices. Any idea on how I can get it to work trough Arduino IDE. Is like the iOS device is not able to detect the esp32 through ble. I have tried many things but its just dont work. Has anyone come across this that could guide me please. Thanks.
Re: WiFi Prov BLE Arduino Not Working for iOS Devices
Even I have faced some issues with BLE provisioning for Arduino + RainMaker, but it was for iOS as well as Android. We haven't yet found the root cause, but will check if it is linked to specific ESP IDF version, because we don't see such issues with the raw RainMaker projects compiled with esp-idf.
maialbe2823
Yeah, I am out of choices here of why it works perfectly only for Android and not iOS maybe is the esp-idf version but I have tried 2 versions already and I still got the same issue.
baudenbacher
I have exactly the same problem. (Compiling RMaker switch on the Arduino Platform) iOS does not find the Bluetooth device and the app throws the error: No bluetooth device found with given prefix. I tried it manually and with a different prefix and no luck. Very desperate to get it running.
I found on the forum that it works with the ESP/Eclipse platform. Should I ditch the Ardunio IDE? I hope to use this as an educational tool and the students are familiar with the Ardunio IDE! Need to get this working!
