Can I un-brick my dev board after unknowingly uploading alternate app when secure boot was enabled
brahmajit
Postby brahmajit » Tue Mar 08, 2022 7:58 am
I was testing out secureboot on a dev board, then by mistake I uploaded another app onto the device (I forgot secure boot was enabled, reflashable option). Not I can upload apps onto my device but get
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:7576
load:0x40078000,len:19720
load:0x40080400,len:3820
0x40080400: _init at ??:?
secure boot check fail
ets_main.c 371
ets Jun  8 2016 00:22:57
Any possibility to unbrick my device or do I consider this board gone :roll:
Also I would be nice if there was a way to test secureboot without writing to the ABS_DONE_0 fuse or if ABS_DONE_0 was rewritable like the FLASH_CRYPT_CNT fuse.
Related issue: https://github.com/espressif/esptool/issues/699
WiFive
Re: Can I un-brick my dev board after unknowingly uploading alternate app when secure boot was enabled
Postby WiFive » Tue Mar 08, 2022 3:41 pm
If you enabled reflashable you should have the keys from when you flashed the other app or did you delete them?
brahmajit
Postby brahmajit » Tue Mar 08, 2022 4:25 pm
I've the keys
WiFive
Postby WiFive » Tue Mar 08, 2022 5:39 pm
Well then you can sign and flash new apps and bootloaders.
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot], PetalBot, Qwantbot, Semrush [Bot] and 1 guest
