Upgrading from 4.3.2 to 4.4 gives virtual environment script errors
Posted: Tue Mar 15, 2022 8:08 pm
by greyarea
I am running ESP-IDF 4.3.2 (in ~home/docs/code/esp/esp-idf) and downloaded the 4.4 ZIP file to put it alongside my esp-idf directory in ../esp-idf-release-v4.4
I have the prerequisites listed but when I run ./install.sh I get the below error - note that I am NOT running it from a virtual environment. What's the correct/best way to upgrade to 4.4?
$ ./install.sh
Detecting the Python interpreter
Checking "python" ...
Python 3.8.10
"python" has been detected
Installing ESP-IDF tools
Selected targets are: esp32c3, esp32s2, esp32, esp32s3
Installing tools: xtensa-esp32-elf, xtensa-esp32s2-elf, xtensa-esp32s3-elf, riscv32-esp-elf, esp32ulp-elf, esp32s2ulp-elf, openocd-esp32
Installing xtensa-esp32-elf@esp-2021r2-patch3-8.4.0
Downloading xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/dist/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz.tmp
Done
Extracting /home/mattb/.espressif/dist/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0
Installing xtensa-esp32s2-elf@esp-2021r2-patch3-8.4.0
Downloading xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/dist/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz.tmp
Done
Extracting /home/mattb/.espressif/dist/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/tools/xtensa-esp32s2-elf/esp-2021r2-patch3-8.4.0
Installing xtensa-esp32s3-elf@esp-2021r2-patch3-8.4.0
Downloading xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/dist/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz.tmp
Done
Extracting /home/mattb/.espressif/dist/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch3-8.4.0
Installing riscv32-esp-elf@esp-2021r2-patch3-8.4.0
Downloading riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/dist/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz.tmp
Done
Extracting /home/mattb/.espressif/dist/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch3-linux-amd64.tar.gz to /home/mattb/.espressif/tools/riscv32-esp-elf/esp-2021r2-patch3-8.4.0
Skipping esp32ulp-elf@2.28.51-esp-20191205 (already installed)
Skipping esp32s2ulp-elf@2.28.51-esp-20191205 (already installed)
Installing openocd-esp32@v0.11.0-esp32-20211220
Downloading openocd-esp32-linux-amd64-0.11.0-esp32-20211220.tar.gz to /home/mattb/.espressif/dist/openocd-esp32-linux-amd64-0.11.0-esp32-20211220.tar.gz.tmp
Done
Extracting /home/mattb/.espressif/dist/openocd-esp32-linux-amd64-0.11.0-esp32-20211220.tar.gz to /home/mattb/.espressif/tools/openocd-esp32/v0.11.0-esp32-20211220
Installing Python environment and packages
fatal: not a git repository (or any of the parent directories): .git
WARNING: Git describe was unsuccessful: b''
ERROR: This script was called from a virtual environment, can not create a virtual environment again
Re: Upgrading from 4.3.2 to 4.4 gives virtual environment script errors
Posted: Thu Mar 17, 2022 8:25 am
by Roland
The error indicates that you are running the install script in a terminal where tools were already set up for use by sourcing export.sh.
The solution is to run it in a clean terminal.
Your path indicates that you might be using Vscode. If that is the case then please look for proper upgrade guide in the vscode extention github repository.
