Parsing sections error
Posted: Thu Mar 17, 2022 7:57 pm
Hello, Im compiling for esp32 and I cant fix this error:
[2/6] Generating ld/sections.ld
FAILED: esp-idf/esp_system/ld/sections.ldCode: Select all
File "/home/rafael/esp/esp-idf/tools/ldgen/entity.py", line 136, in add_sections_info
results = parser.parseString(first_line, parseAll=True)
File "/home/rafael/.espressif/python_env/idf4.4_py3.9_env/lib/python3.9/site-packages/pyparsing.py", line 1814, in parseString
raise exc
File "/home/rafael/.espressif/python_env/idf4.4_py3.9_env/lib/python3.9/site-packages/pyparsing.py", line 1804, in parseString
loc, tokens = self._parse( instring, 0 )
File "/home/rafael/.espressif/python_env/idf4.4_py3.9_env/lib/python3.9/site-packages/pyparsing.py", line 1548, in _parseNoCache
loc,tokens = self.parseImpl( instring, preloc, doActions )
File "/home/rafael/.espressif/python_env/idf4.4_py3.9_env/lib/python3.9/site-packages/pyparsing.py", line 3705, in parseImpl
loc, resultlist = self.exprs[0]._parse( instring, loc, doActions, callPreParse=False )
File "/home/rafael/.espressif/python_env/idf4.4_py3.9_env/lib/python3.9/site-packages/pyparsing.py", line 1552, in _parseNoCache
File "/home/rafael/.espressif/python_env/idf4.4_py3.9_env/lib/python3.9/site-packages/pyparsing.py", line 4067, in parseImpl
return self.expr._parse( instring, loc, doActions, callPreParse=False )
File "/home/rafael/.espressif/python_env/idf4.4_py3.9_env/lib/python3.9/site-packages/pyparsing.py", line 2625, in parseImpl
raise ParseException(instring, loc, self.errmsg, self)
pyparsing.ParseException: Expected "In archive" (at char 0), (line:1, col:1)
During handling of the above exception, another exception occurred:
File "/home/rafael/esp/esp-idf/tools/ldgen/ldgen.py", line 178, in <module>
main()
File "/home/rafael/esp/esp-idf/tools/ldgen/ldgen.py", line 136, in main
sections_infos.add_sections_info(dump)
File "/home/rafael/esp/esp-idf/tools/ldgen/entity.py", line 138, in add_sections_info
raise ParseException('Parsing sections info for library ' + sections_info_dump.name + ' failed. ' + p.msg)
pyparsing.ParseException: Parsing sections info for library /home/rafael/esp/ULIP32/build/esp-idf/esp_ringbuf/libesp_ringbuf.a failed. Expected "In archive" (at char 0), (line:1, col:1)
ninja failed with exit code 1
