Cannot include <stdint.h> , Eclipse ESP-IDF
Posted: Fri Mar 18, 2022 9:47 pm
by Hailwiz9
I have used arduino before and I can be said to be a beginner in terms of C, C++
I wanted to learn more in-depth coding by diving into the ESP-IDF environment, I'm using Eclipse IDE,
I'm trying to convert the DMD32 library which was written for arduino to be used in ESP-IDF but got stuck at some type declarations.
I can't seem to include "uint8_t" into the C type Header file,
I've figured if I included <stdint.h> it would work but the IDE can't seem to find the library.
I don't know if this problem is with the Eclipse IDE or I'm doing something wrong with file types or such, tried to find Path options in Eclipse IDE but can't seem to find it.
Example code is given below, and the Eclipse IDE response can be seen in the attachment picture
Thanks for your help,
Code: DMD32.cpp Select all
[Codebox] ---
#pragma once
#ifndef MAIN_DMD32_H_
#define MAIN_DMD32_H_
#include <stdint.h>
#ifdef __cplusplus
extern "C" {
#endif
//drawTestPattern Patterns2
#define PATTERN_ALT_0 0
#define PATTERN_ALT_1 1
#define PATTERN_STRIPE_0 2
#define PATTERN_STRIPE_1 3
//display screen (and subscreen) sizing
#define DMD_PIXELS_ACROSS 32 //pixels across x axis (base 2 size expected)
#define DMD_PIXELS_DOWN 16 //pixels down y axis
#define DMD_BITSPERPIXEL 1 //1 bit per pixel, use more bits to allow for pwm screen brightness control
#define DMD_RAM_SIZE_BYTES ((DMD_PIXELS_ACROSS*DMD_BITSPERPIXEL/8)*DMD_PIXELS_DOWN)
// (32x * 1 / 8) = 4 bytes, * 16y = 64 bytes per screen here.
//lookup table for DMD::writePixel to make the pixel indexing routine faster
static uint8_t bPixelLookupTable[8] =
0x80, //0, bit 7
0x40, //1, bit 6
0x20, //2. bit 5
0x10, //3, bit 4
0x08, //4, bit 3
0x04, //5, bit 2
0x02, //6, bit 1
0x01 //7, bit 0
