I have a Adafruit ESP32 feather that will not compile with a MAC and Arduino. I have followed all the info provided by Adafruit and feel that something is missing. What info do I need in the Arduino preferences for the additional boards URLs: text box ? What is entered now is the info needed for a ESP8266, is this my hang? I tried to compile with this entry left blank and no luck.
Is there some go to site that provides the ultimate noob with a step by step procedure to initiate an ESP32 and Arduino API?
Code will not compile with Arduino
Re: Code will not compile with Arduino
Installs just fine but I use Ubuntu Linux. If you are using Windows, try this.
http://randomnerdtutorials.com/installi ... tructions/
Do not change the boards URL in the preferences window. This will not help and might mess up your existing board packages.
Maybe this is what you are looking for (was posted as an issue https://github.com/espressif/arduino-esp32/issues/532) :
I would like to mention that the Arduino IDE installation should not always be located under:
But under the location defined in the~/Documents/Arduino/.... typically ~/Documents/Arduino/hardware/espressif
settings (from the top Arduino Menu) hasArduino Preferences
For example in my case the location is defined as:Sketchbook location:
The practical location of the "Arduino core for ESP32 WiFi chip" kit should be:/Users/Robert/Data/Our Documents/Projets Techniques/Domotic/Arduino/Sketch
Robert/Users/Robert/Data/Our Documents/Projets Techniques/Domotic/Arduino/hardware/espressif
Users browsing this forum: ChatGPT-User, Google [Bot] and 4 guests
