Third party integration
dalohar
Postby dalohar » Fri Mar 25, 2022 9:39 am
Greetings!
I wish to understand that how 3rd party integration works in ESP-Rainmaker with help of following points.
1. Does alexa/google home assistant finds new devices locally or it get device list through alexa skill?
2. If through alexa skill then what is rough workflow for the same.
3. Also can we have our own cloud services like esp-rainmaker? If so then what are the ways to get it done (any examples/tutorials)?
4. How can we develop alexa skill or customize esp-rainmaker skill (any examples/tutorials)?
5. Also do we have to use amazon cloud only or can we go for google cloud services and how?
Please guide me on the same.
Regards,
Dinesh
Piyush
Re: Third party integration
Postby Piyush » Fri Mar 25, 2022 1:15 pm
Alexa/Google get the devices using Alexa Skills/Google Actions. They don't get it over local network.
If you check out the steps to enable Alexa or Google Voice Assistant(GVA), you will see that you give RainMaker account access to Alexa/GVA and then ask them to discover the devices. Alexa/GVA then send a query to the RainMaker Alexa Skill/GVA action, which then fetches all the information from RainMaker backend, using the appropriate REST APIs. The response is then parsed and reformatted as per the Alexa/GVA specs and then sent back. Similar calls happens when you get/set any values.
We provide private RainMaker deployments for commercial purposes. You can contact our sales team for more information on that.
The skill code itself is not open. However, since the Smart Home Skills/Actions have very specific requirements defined by Alexa/Google, the default skills are generally sufficient. We do not yet support all device types, but we do add new ones based on feature requests.
ESP RainMaker is built using AWS Serverless services and so, cannot be easily migrated to other cloud platforms.
dalohar
Postby dalohar » Sat Mar 26, 2022 5:05 am
Thanks for your reply. I will study further and will get back if needed.
