Hello, My firstESP32 !
Jul 25 2017 17:55:07
...Code: Select all
lobal variables use 32828 bytes (11%) of dynamic memory, leaving 262084 bytes for local variables. Maximum is 294912 bytes.
esptool.py v2.0-beta3
Connecting.....I also have/had a Sparkfun Thing and had no problems with it which makes me think this is either a problem with the device, or the Mac serial driver (the Sparkfun uses an FTDI chip which uses a different driver). I'm pretty sure the version I bought from the above Aliexpress seller is a clone, however I'm not sure if that is the reason uploads fail, after all, someone somehow managed to flash the blink program that came with the device... Any ideas what might be wrong?
