ESP32 Wrover B PCB Design
Jay Vadoliya
Postby Jay Vadoliya » Mon Apr 11, 2022 8:34 am
After Some problems in previous board I am designing new board with ESP32 Wrover B and i am using reference design of module but there are some questions that i want to ask before sending this design to PCB routing.
1.Why IO22 and IO21 is pulled up ?
2.Is there any other protection required in power supply of ESP32-Wrover(like Transient Surepression and Overvoltage)
3.Is it overkill to add 470uf Capacitor in power supply?
4.What are some important things to consider while PCB routing of module?
Minatel
Re: ESP32 Wrover B PCB Design
Postby Minatel » Mon Apr 11, 2022 9:48 am
1 - Why did you pulled-up IO22 and IO21?
2 - It's on our Reference Design one TVS in the 3V3 supply.
3 - It depends on your power supply. For your design, I think it is, but I don't know about your power supply capabilities.
4 - You can see all reference design material from Espressif. You can follow all the best practices from this document.
Jay Vadoliya
Postby Jay Vadoliya » Mon Apr 11, 2022 10:00 am
We did working Prototype with LILYGO Board so for reference we used schematic of same board. In schematic of board IO21 & IO22 is pulled up.
5V power supply is taken From Industrial SMPS which can deliver 3 to 4 amps
schematic file is attached.
LilyGo-SIM800L-IP5306-20190610.pdf
(96.6 KiB) Downloaded 273 times
Minatel
Postby Minatel » Mon Apr 11, 2022 10:40 am
If you take a look at the schematics, you will see that the IP5306-I2C is connected to the IO21 and IO22.
Screenshot from 2022-04-11 11-39-38.png (234.31 KiB) Viewed 3905 times
Jay Vadoliya
Postby Jay Vadoliya » Mon Apr 11, 2022 10:49 am
what about 470uf capacitor i dont generally see this heavy capacitor on any board
Minatel
Postby Minatel » Mon Apr 11, 2022 3:39 pm
I see no advantage in using this large capacitor since you have a good power source.
