ESP master receive data seems >> 1, when using SPI communication between two ESP32
L1ght1
Postby L1ght1 » Mon Apr 11, 2022 9:08 am
I'm trying using SPI communication between two ESP32. The slave can receive data from master correctly, but the master receive data from slave seems shift right one place. The result displays as follows.
I would appreciate it if someone could help me.
Both slave and master code are come from example.
slave send:
I (552736) [no-router, 235]: send:a
I (553237) [no-router, 235]: send:a
I (553736) [no-router, 235]: send:a
I (554240) [no-router, 235]: send:a
I (554740) [no-router, 235]: send:a
I (555242) [no-router, 235]: send:a
I (555738) [no-router, 235]: send:a
I (556238) [no-router, 235]: send:a
I (556742) [no-router, 235]: send:a
I (557238) [no-router, 235]: send:a
I (557743) [no-router, 235]: send:a
I (558240) [no-router, 235]: send:a
master receive
I (523864) [no-router, 183]: Recieved data 0
I (524365) [no-router, 183]: Recieved data 0
I (524866) [no-router, 183]: Recieved data @
I (525366) [no-router, 183]: Recieved data @
I (525866) [no-router, 183]: Recieved data @
I (526366) [no-router, 183]: Recieved data 0
I (526866) [no-router, 183]: Recieved data @
I (527366) [no-router, 183]: Recieved data @
I (527866) [no-router, 183]: Recieved data 0
I (528366) [no-router, 183]: Recieved data @
I (528866) [no-router, 183]: Recieved data @
I (529366) [no-router, 183]: Recieved data 0
I (529867) [no-router, 183]: Recieved data 0
I (530368) [no-router, 183]: Recieved data @
slave code:
static mdf_err_t spi_initialize()
    esp_err_t ret;
    //Configuration for the SPI bus
    spi_bus_config_t buscfg={
        .mosi_io_num=GPIO_MOSI,
        .miso_io_num=GPIO_MISO,
        .sclk_io_num=GPIO_SCLK,
        .quadwp_io_num = -1,
        .quadhd_io_num = -1,
    //Configuration for the SPI slave interface
    spi_slave_interface_config_t slvcfg={
        .mode=0,
        .spics_io_num=GPIO_CS,
        .queue_size=3,
        .flags=0,
        .post_setup_cb=my_post_setup_cb,
        .post_trans_cb=my_post_trans_cb
    //Configuration for the SPI device on the other side of the bus
    spi_device_interface_config_t devcfg={
        .command_bits=0,
        .address_bits=0,
        .dummy_bits=0,
        .clock_speed_hz=5000000,
        .duty_cycle_pos=128,        //50% duty cycle
        .mode=0,
        .cs_ena_posttrans=3,        //Keep the CS low 3 cycles after transaction, to stop slave from missing the last bit when CS has less propagation delay than CLK
        .queue_size=3
    //Configuration for the handshake line
    gpio_config_t io_conf={
        .intr_type=GPIO_INTR_DISABLE,
        .mode=GPIO_MODE_OUTPUT,
        .pin_bit_mask=(1<<GPIO_HANDSHAKE)
    //Configure handshake line as output
    gpio_config(&io_conf);
    //Enable pull-ups on SPI lines so we don't detect rogue pulses when no master is connected.
    gpio_set_pull_mode(GPIO_MOSI, GPIO_PULLUP_ONLY);
    gpio_set_pull_mode(GPIO_SCLK, GPIO_PULLUP_ONLY);
    gpio_set_pull_mode(GPIO_CS, GPIO_PULLUP_ONLY);
    //Initialize SPI slave interface
    ret=spi_slave_initialize(RCV_HOST, &buscfg, &slvcfg, DMA_CHAN);
    assert(ret==ESP_OK);
    return MDF_OK;
    static void spi_handle_task(void *arg)
    int recv_length   = 0;
    mdf_err_t ret     = MDF_OK;
    cJSON *json_root  = NULL;
    cJSON *json_addr  = NULL;
    cJSON *json_group = NULL;
    cJSON *json_data  = NULL;
    cJSON *json_dest_addr  = NULL;
    // Configure a temporary buffer for the incoming data
    uint8_t *data                     = (uint8_t *) MDF_MALLOC(BUF_SIZE);
    size_t size                       = MWIFI_PAYLOAD_LEN;
    char *jsonstring                  = NULL;
    uint8_t dest_addr[MWIFI_ADDR_LEN] = {0};
    mwifi_data_type_t data_type       = {0};
    uint8_t sta_mac[MWIFI_ADDR_LEN]   = {0};
    MDF_LOGI("Uart handle task is running");
    esp_wifi_get_mac(ESP_IF_WIFI_STA, sta_mac);
    /* spi initialization */
    MDF_ERROR_ASSERT(spi_initialize());
    int n = 0;
    WORD_ALIGNED_ATTR char sendbuf[129]="";
    WORD_ALIGNED_ATTR char recvbuf[129]="";
    memset(sendbuf, 0, 33);
    spi_slave_transaction_t t;
    memset(&t, 0, sizeof(t));
    sprintf(sendbuf, "a");
    memset(recvbuf, '\0', 129);
    while (1) {
        t.length=128*8;
        t.tx_buffer=sendbuf;
        t.rx_buffer=recvbuf;
        //xSemaphoreTake(rdySem, portMAX_DELAY);
        MDF_LOGI("send:%s",sendbuf);
        ret=spi_slave_transmit(RCV_HOST, &t, portMAX_DELAY);
master code:
spi_bus_handle_t bus_handle = NULL;
spi_bus_device_handle_t device_handle = NULL;
    spi_config_t bus_conf = {
        .miso_io_num = PIN_NUM_MISO,
        .mosi_io_num = PIN_NUM_MOSI,
        .sclk_io_num = PIN_NUM_CLK,
    }; // spi_bus configurations
    spi_device_config_t device_conf = {
        .cs_io_num = PIN_NUM_CS,
        .mode = 0,
        .clock_speed_hz = 20 * 1000 * 1000,
    }; // spi_device configurations
    gpio_pad_select_gpio(PIN_NUM_CS);                // 选择一个GPIO
    gpio_set_direction(PIN_NUM_CS, GPIO_MODE_OUTPUT);// 把这个GPIO作为输出
    gpio_pad_select_gpio(GPIO_HANDSHAKE);                // 选择一个GPIO
    gpio_set_direction(GPIO_HANDSHAKE, GPIO_MODE_OUTPUT);// 把这个GPIO作为输出
    bus_handle = spi_bus_create(SPI2_HOST, &bus_conf); // create spi bus
    device_handle = spi_bus_device_create(bus_handle, &device_conf); // create spi device
    return MDF_OK;
    while (1) {
        memset(data, 0, BUF_SIZE);
        char* stl = "{\"dest_addr\":\"78:e3:6d:cd:17:6c\",\"data\":\"contentbb\"}";
        gpio_set_level(PIN_NUM_CS, 0);
        int ret = spi_bus_transfer_bytes(device_handle, (uint8_t *)stl, data, BUF_SIZE); // BUF_SIZE only read 1 byte with spi device
        gpio_set_level(PIN_NUM_CS, 1);
        MDF_ERROR_CONTINUE(ret != ESP_OK, "SPI transfer bytes fail, data: %s", data);
        MDF_LOGI("Recieved data %s", data);
         vTaskDelay(500);
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User and 3 guests
