abort() was called at PC 0x... on core 1
A001FF
Postby A001FF » Tue Apr 19, 2022 10:49 am
How can I find where in the source program is the line that generates the error?
CORRUPT HEAP: Bad tail at 0x3ffb8695. Expected 0xbaad5678 got 0xbaad560d
abort() was called at PC 0x400832fd on core 1
Backtrace: 0x40084e80:0x3ffb1af0 ...
Rebooting...
Re: abort() was called at PC 0x... on core 1
Postby Sprite » Wed Apr 20, 2022 12:53 am
It depends. In esp-idf, it's easiest to use 'idf.py monitor' as your terminal program, as it automagically decodes those addresses. In Arduino, your best bet is EspExceptionDecoder.
A001FF
Postby A001FF » Wed Apr 20, 2022 1:17 pm
ESP_Sprite many, many thanks !
Of corse, overflow :)
len=512;
buf = (char *)malloc(len);
buf[len]=0x00; <-- :)
free(buf); <-- that is the line reported by tools EspExceptionDecoder (interesting).
Postby Sprite » Thu Apr 21, 2022 1:05 am
Nice that you found it. buf[len]=0 doesn't give an error as there still is valid memory one byte past the end of the array, and C doesn't do runtime bound checks, so it happily will write there. However, one byte past the bounds check is a magic word used by the memory allocator, and the write corrupts this word. free() will check this word, note it's corrupted and abort.
sridharallamraju
Postby sridharallamraju » Mon Mar 06, 2023 4:48 am
Hi.
I've used this code to join in the helium LoRaWAN. I ended up with the following error. I am not sure what to do.
ELF file SHA256: 0000000000000000
Rebooting...
ESP32 MCU init...
abort() was called at PC 0x4008258e on core 1
Backtrace:0x40083ca9:0x3ffb26600x400891bd:0x3ffb2680 0x4008dfa1:0x3ffb26a0 0x4008258e:0x3ffb2720 0x40082b64:0x3ffb2770 0x400d4c28:0x3ffb2790 0x400d53b9:0x3ffb27b0 0x400d1869:0x3ffb27f0 0x400db332:0x3ffb2820
Rebooting...
ESP32 MCU init...
* HelTec Automation(TM) LoRaWAN 1.0.2 OTAA example use OTAA, CLASS A
* Function summary:
* - use internal RTC(150KHz);
* - Include stop mode and deep sleep mode;
* - 15S data send cycle;
* - Informations output via serial(115200);
* - Only ESP32 + LoRa series boards can use this library, need a license
* to make the code run(check you license here: http://www.heltec.cn/search/);
* You can change some definition in "Commissioning.h" and "LoRaMac-definitions.h"
* HelTec AutoMation, Chengdu, China.
* 成都惠利特自动化科技有限公司
* https://heltec.org
* support@heltec.cn
*this project also release in GitHub:
*https://github.com/HelTecAutomation/ESP32_LoRaWAN
#include <ESP32_LoRaWAN.h>
#include "Arduino.h"
/*license for Heltec ESP32 LoRaWan, quary your ChipID relevant license: http://resource.heltec.cn/search */
uint32_t license[4] = {0x9891D573,0x9A5B9C72,0x33524BC4,0xA7121228};
/* OTAA para*/
uint8_t DevEui[] = {------------------------- };
uint8_t AppEui[] = { ----------------------------------------------- };
uint8_t AppKey[] = {----------------------------------------------------------------------- };
/* ABP para*/
uint8_t NwkSKey[] = { 0x15, 0xb1, 0xd0, 0xef, 0xa4, 0x63, 0xdf, 0xbe, 0x3d, 0x11, 0x18, 0x1e, 0x1e, 0xc7, 0xda,0x85 };
uint8_t AppSKey[] = { 0xd7, 0x2c, 0x78, 0x75, 0x8c, 0xdc, 0xca, 0xbf, 0x55, 0xee, 0x4a, 0x77, 0x8d, 0x16, 0xef,0x67 };
uint32_t DevAddr = ( uint32_t )0x007e6ae1;
/*LoraWan channelsmask, default channels 0-7*/
uint16_t userChannelsMask[6]={ 0x00FF,0x0000,0x0000,0x0000,0x0000,0x0000 };
/*LoraWan Class, Class A and Class C are supported*/
DeviceClass_t loraWanClass = CLASS_A;
/*the application data transmission duty cycle. value in [ms].*/
uint32_t appTxDutyCycle = 15000;
/*OTAA or ABP*/
bool overTheAirActivation = true;
/*ADR enable*/
bool loraWanAdr = true;
/* Indicates if the node is sending confirmed or unconfirmed messages */
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
* Number of trials to transmit the frame, if the LoRaMAC layer did not
* receive an acknowledgment. The MAC performs a datarate adaptation,
* according to the LoRaWAN Specification V1.0.2, chapter 18.4, according
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
* Note, that if NbTrials is set to 1 or 2, the MAC will not decrease
* the datarate, in case the LoRaMAC layer did not receive an acknowledgment
uint8_t confirmedNbTrials = 8;
/*LoraWan debug level, select in arduino IDE tools.
* None : print basic info.
* Freq : print Tx and Rx freq, DR info.
* Freq && DIO : print Tx and Rx freq, DR, DIO0 interrupt and DIO1 interrupt info.
* Freq && DIO && PW: print Tx and Rx freq, DR, DIO0 interrupt, DIO1 interrupt and MCU deepsleep info.
uint8_t debugLevel = LoRaWAN_DEBUG_LEVEL;
/*LoraWan region, select in arduino IDE tools*/
LoRaMacRegion_t loraWanRegion = ACTIVE_REGION;
static void prepareTxFrame( uint8_t port )
appDataSize = 4;//AppDataSize max value is 64 ( src/Commissioning.h -> 128 )
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
// Add your initialization code here
void setup()
while (!Serial);
SPI.begin(SCK,MISO,MOSI,SS);
Mcu.init(SS,RST_LoRa,DIO0,DIO1,license);
deviceState = DEVICE_STATE_INIT;
// The loop function is called in an endless loop
void loop()
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
LoRaWAN.generateDeveuiByChipID();
#endif
LoRaWAN.init(loraWanClass,loraWanRegion);
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send(loraWanClass);
deviceState = DEVICE_STATE_CYCLE;
case DEVICE_STATE_CYCLE:
// Schedule next packet transmission
txDutyCycleTime = appTxDutyCycle + randr( -APP_TX_DUTYCYCLE_RND, APP_TX_DUTYCYCLE_RND );
LoRaWAN.cycle(txDutyCycleTime);
deviceState = DEVICE_STATE_SLEEP;
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass,debugLevel);
default:
Aurélio Marko
Postby Aurélio Marko » Thu Jan 25, 2024 5:04 pm
Hi, i am using o heltec stick lite with the ESP32_LoRaWAN library on PlatiformIO, but my code is crashing. The message returned is this:
abort() was called at PC 0x40082132 on core 1
I tried to use the EspExceptionDecoder, but the line that is crashing is at MCU.init, when i try to access the code i only get the .h code and not the .cpp code. When i use the same library and same board at the Arduino IDE everything run fine...
Any one has some idea what is hapaning???
Users browsing this forum: ChatGPT-User and 3 guests
