ESP32-Ethernet-Kit开发板 ,通过JTAG 烧录程序确正常, 但是使用JTAG仿真时报错
Posted: Thu Apr 21, 2022 8:12 am
环境:win10 + Vscode
ESP32-Ethernet-Kit开发板 ,通过JTAG 烧录程序确正常, 但是使用JTAG仿真时报错 如下
1, start OpenOCD 报错日志如下
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Warn : target esp32.cpu1 examination failed
Info : starting gdb server for esp32.cpu0 on 3333
2,F5仿真运行报错信息如下
Debug adapter -> Extension: DEBUG_ADAPTER_STARTED
Debug adapter -> Extension: DEBUG_ADAPTER_READY2CONNECT
Debug Adapter initialized
Failed to wait for target state 1! Current state 2
2,F5仿真运行报错信息如下
