Not Able to Program ESP32
Posted: Fri May 06, 2022 3:37 pm
by brn100
Dear all,
I have a great issue while wanted to program ESP32-WROOM-32E MCU idle, without using any development boards. I am using CH340G USB-to-UART adapter for external connection. In order to supply ESP32, I am using LM1117 LDO regulator(5V to 3.3V).
I continuously get the following message on serial monitor when I wanted to program my ESP32-WROOM-32E over Arduino:
ets Jul 29 2019 12:21:46
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:12784
load:0x40080400,len:3032
entry 0x400805e4
factory_parameter partition missed
[0;31mE (633) phy_init: failed to validate PHY data partition[0m
[0;31mE (633) phy_init: failed to obtain PHY init data[0m
abort() was called at PC 0x400e43ef on core 0
ELF file SHA256: f19ef370db8aae99
Backtrace: 0x4008d09d:0x3ffcccf0 0x4008d409:0x3ffccd10 0x400e43ef:0x3ffccd30 0x401a75c8:0x3ffccd60 0x401a7691:0x3ffccd80 0x401a792a:0x3ffccda0 0x401a47f6:0x3ffccdc0 0x400968aa:0x3ffccde0 0x4008e89d:0x3ffcce10
Rebooting...
Apart from that, the other problem is when I wanted to upload a code into the chip, I get the following error:
esptool.py v3.3-dev
Serial port /dev/ttyUSB0
Connecting.....................................An error occurred while uploading the sketch
A fatal error occurred: Failed to connect to ESP32: No serial data received.
What do you think about the problem? I had attached the schematic that I used.
Thanks for your attention,
Baran
Re: Not Able to Program ESP32
Posted: Sat May 07, 2022 4:59 am
by Sprite
Can you check what happens if you manually ground GPIO0, reset the ESP32 and then re-try programming it?
