Page 1 of 2
My ESP-32 EVK with sd card,codec and eth
Posted: Mon Aug 21, 2017 1:20 am
by frankie.zeng
it looks like this:
The evk board contains:
1.micro usb +cp2104 (use esptool.py can download the code to flash directly)
2.sd card (4 bits)
3.audio codec (wm8978,with headphone,5w speaker and mic)
4.eth phy(lan8720A)
more infomation:
https://www.whyengineer.com/esp32/
now you can only from taobao(china),if you are a foreigner,maybe you give me a email(frankie.zengfu@gmail.com) ,i will deliver to you.
Re: My ESP-32 EVK with sd card,codec and eth
Posted: Mon Aug 21, 2017 3:25 am
by igrr
Can you post the board schematic on the Wiki or on Github?
Posted: Mon Aug 21, 2017 4:17 am
by frankie.zeng
here is SCH and PCB. the wiki page.
https://wiki.whyengineer.com/doku.php?id=esp32:index
Posted: Mon Aug 21, 2017 4:30 am
by igrr
Thanks!
One note on the schematic — you may consider adding a capacitor on the EN line, see 3.1.2.2 in "ESP32 Hardware design guidelines".
(later)
It may also be nice to have all the connectors for cables (USB, Eth, audio) roughly on one side of the board.
Posted: Mon Aug 21, 2017 5:41 am
by frankie.zeng
Thanks!
(later)
yeah,i'm thinking more funning features based on esp32 and the shape will become more beautiful.
Posted: Mon Aug 21, 2017 1:43 pm
by frankie.zeng
use the voltage detect ic can avoild 50M emac clk making the esp32 enter into download mode
Posted: Wed Aug 23, 2017 10:42 am
by igrr
Please add a pin header for JTAG in the next version! Just realized that I have to go back to flashing over UART with this board...
Posted: Fri Sep 08, 2017 4:14 am
by frankie.zeng
this is simple demo video:
https://youtu.be/XmACCHjvG5k
Posted: Fri Sep 08, 2017 6:46 am
by igrr
Btw, i was a bit surprised that when i plugged an Ethernet cable into this board, short circuit happened and the regulator became very hot! Looking at the schematics, i see that you have implemented a kind of PoE where 5V can be fed to the board via the Ethernet cable.
However there is no protection for the case when the board is powered by USB and the cable happens to short 5V and GND... That part of the design definitely needs some kind of a protection circuit.
Posted: Wed Sep 20, 2017 5:35 am
by frankie.zeng
a new demo
ble and wifi gateway
https://youtu.be/ViGX7JULN0U
