[已解决]ESP32-S3连不上WIFI
aacaac50
Postby aacaac50 » Fri May 13, 2022 9:42 am
使用的ESP32-S3的模组,IDF版本是5.0,提交是a82e6e63d98bb051d4c59cb3d440c537ab9f74b0,连接WIFi时会报wifi:AP not PMF Capable when STA requires, reject profile,导致无法连上WIFI.
详细log如下:
D (2480) esp_netif_lwip: LwIP stack has been initialized[0m
D (2480) esp_netif_lwip: esp-netif has been successfully initialized[0m
D (2482) event: created task for loop 0x3fccc1cc[0m
D (2482) event: running task for loop 0x3fccc1cc[0m
D (2486) event: created event loop 0x3fccc1cc[0m
D (2494) esp_netif_objects: esp_netif_add_to_list 0x3fccced4[0m
D (2500) esp_netif_objects: esp_netif_add_to_list netif added successfully (total netifs: 1)[0m
I (2510) pp: pp rom version: e7ae62f
I (2514) net80211: net80211 rom version: e7ae62f
D (2518) nvs: nvs_open_from_partition misc 1[0m
I (2526) wifi:wifi driver task: 3fccf70c, prio:23, stack:6656, core=0
D (2530) nvs: nvs_open_from_partition nvs.net80211 1[0m
D (2534) nvs: nvs_get opmode 1[0m
D (2538) nvs: nvs_get_str_or_blob sta.ssid[0m
D (2542) nvs: nvs_get sta.authmode 1[0m
D (2546) nvs: nvs_get_str_or_blob sta.pswd[0m
D (2550) nvs: nvs_get_str_or_blob sta.pmk[0m
D (2554) nvs: nvs_get sta.chan 1[0m
D (2556) nvs: nvs_get auto.conn 1[0m
D (2560) nvs: nvs_get bssid.set 1[0m
D (2564) nvs: nvs_get_str_or_blob sta.bssid[0m
D (2568) nvs: nvs_get sta.lis_intval 2[0m
D (2572) nvs: nvs_get sta.phym 1[0m
D (2574) nvs: nvs_get sta.phybw 1[0m
D (2578) nvs: nvs_get_str_or_blob sta.apsw[0m
D (2582) nvs: nvs_get_str_or_blob sta.apinfo[0m
D (2588) nvs: nvs_get sta.scan_method 1[0m
D (2590) nvs: nvs_get sta.sort_method 1[0m
D (2594) nvs: nvs_get sta.minrssi 1[0m
D (2598) nvs: nvs_get sta.minauth 1[0m
D (2602) nvs: nvs_get sta.pmf_e 1[0m
D (2606) nvs: nvs_get sta.pmf_r 1[0m
D (2608) nvs: nvs_get sta.btm_e 1[0m
D (2612) nvs: nvs_get sta.rrm_e 1[0m
D (2616) nvs: nvs_get sta.mbo_e 1[0m
D (2618) nvs: nvs_get_str_or_blob ap.ssid[0m
D (2624) nvs: nvs_get_str_or_blob ap.passwd[0m
D (2628) nvs: nvs_get_str_or_blob ap.pmk[0m
D (2632) nvs: nvs_get ap.chan 1[0m
D (2634) nvs: nvs_get ap.authmode 1[0m
D (2638) nvs: nvs_get ap.hidden 1[0m
D (2642) nvs: nvs_get ap.max.conn 1[0m
D (2644) nvs: nvs_get bcn.interval 2[0m
D (2648) nvs: nvs_get ap.phym 1[0m
D (2652) nvs: nvs_get ap.phybw 1[0m
D (2654) nvs: nvs_get ap.sndchan 1[0m
D (2658) nvs: nvs_get ap.pmf_e 1[0m
D (2662) nvs: nvs_get ap.pmf_r 1[0m
D (2664) nvs: nvs_get ap.p_cipher 1[0m
D (2668) nvs: nvs_get lorate 1[0m
D (2672) nvs: nvs_get_str_or_blob country[0m
D (2676) nvs: nvs_get ap.ftm_r 1[0m
D (2680) nvs: nvs_set ap.sndchan 1 1[0m
I (2682) wifi:wifi firmware version: e887b51
I (2686) wifi:wifi certification version: v7.0
I (2690) wifi:config NVS flash: enabled
I (2694) wifi:config nano formating: disabled
I (2698) wifi:Init data frame dynamic rx buffD (2702) efuse: In EFUSE_BLK2__DATA4_REG is used 2 bits starting with 0 bit[0m
D (2710) efuse: In EFUSE_BLK2__DATA4_REG is used 8 bits starting with 21 bit[0m
D (2716) efuse: In EFUSE_BLK2__DATA4_REG is used 3 bits starting with 29 bit[0m
D (2724) efuse: In EFUSE_BLK2__DATA5_REG is used 3 bits starting with 0 bit[0m
D (2730) efuse: In EFUSE_BLK2__DATA5_REG is used 6 bits starting with 3 bit[0m
D (2738) efuse: In EFUSE_BLK2__DATA5_REG is used 6 bits starting with 9 bit[0m
er num: 32
I (2746) wifi:Init management frame dynamic rx buffer num: 32
I (2752) wifi:Init management short buffer num: 32
I (2756) wifi:Init static tx buffer num: 16
I (2760) wifi:Init tx cache buffer num: 32
I (2764) wifi:Init static tx FG buffer num: 2
I (2768) wifi:Init static rx buffer size: 1600
I (2772) wifi:Init static rx buffer num: 10
I (2776) wifi:Init dynamic rx buffer num: 32
I (2780) wifi_init: rx ba win: 6
I (2784) wifi_init: tcpip mbox: 32
I (2788) wifi_init: udp mbox: 6
I (2792) wifi_init: tcp mbox: 6
I (2794) wifi_init: tcp tx win: 5744
I (2800) wifi_init: tcp rx win: 5744
I (2804) wifi_init: tcp mss: 1440
I (2808) wifi_init: WiFi/LWIP prefer SPIRAM
D (2812) nvs: nvs_get opmode 1[0m
D (3816) nvs: nvs_get_str_or_blob BleConfWiFiSSID[0m
D (3816) nvs: nvs_get_str_or_blob BleConfWiFiPW[0m
I (3816) wifi: 检测到有配网的数据,SSID:AAC@NET,密码:AACAAC50
D (3820) wifi:clear blacklist
D (3824) nvs: nvs_set_blob sta.ssid 36[0m
D (3828) nvs: nvs_set_blob sta.pswd 65[0m
D (3832) nvs: nvs_set bssid.set 1 0[0m
D (3834) nvs: nvs_set sta.lis_intval 2 3[0m
D (3838) nvs: nvs_set sta.chan 1 0[0m
D (3842) nvs: nvs_set sta.scan_method 1 0[0m
D (3846) nvs: nvs_set sta.sort_method 1 0[0m
D (3850) nvs: nvs_set sta.minrssi 1 -127[0m
D (3854) nvs: nvs_set sta.minauth 1 0[0m
D (3858) nvs: nvs_set_blob sta.apsw 2[0m
D (3862) nvs: nvs_set sta.pmf_e 1 1[0m
D (3866) nvs: nvs_set sta.pmf_r 1 80[0m
D (3870) nvs: nvs_set sta.rrm_e 1 0[0m
D (3872) nvs: nvs_set sta.btm_e 1 0[0m
D (3876) nvs: nvs_set sta.mbo_e 1 0[0m
D (3880) nvs: nvs_set_blob sta.apinfo 700[0m
D (3886) ADC: Wi-Fi takes adc2 lock.[0m
D (3888) wifi:filter: set rx policy=0
I (3890) wifi:mode : sta (7c:de:a0:e0:86:e8)
I (3894) wifi:enable tsf
D (3896) wifi:filter: set rx policy=1
D (3900) wifi:connect status 0 -> 0
D (3904) wifi:Start wifi connect
D (3906) wifi:connect status 0 -> 0
D (3910) wifi:connect chan=0
D (3912) wifi:first chan=1
D (3914) wifi:connect status 0 -> 1
D (3918) wifi:filter: set rx policy=3
D (3922) wifi:clear scan ap list
D (3924) wifi:start scan: type=0x50f, priority=2, cb=0x420c7d28, arg=0x0, ss_state=0x1, time=3929823, index=0
D (3934) wifi:perform scan: ss_state=0x9, chan<1,0>, dur<0,120>
D (3940) event: running post WIFI_EVENT:2 with handler 0x42078a2c and context 0x3fccd000 on loop 0x3fccc1cc[0m
D (3950) wifi_init_default: wifi_start esp-netif:0x3fccced4 event-id2[0m
D (3956) wifi_init_default: WIFI mac address: 7c de a0 e0 86 e8[0m
D (3962) esp_netif_handlers: esp_netif action has started with netif0x3fccced4 from event_id=2[0m
D (3970) esp_netif_lwip: check: remote, if=0x3fccced4 fn=0x4207288c
[0m
D (3978) esp_netif_lwip: esp_netif_start_api 0x3fccced4[0m
D (3982) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3fccced4[0m
D (3988) esp_netif_lwip: check: local, if=0x3fccced4 fn=0x42073280
[0m
D (3996) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fccced4[0m
D (4002) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (4008) event: running post WIFI_EVENT:2 with handler 0x4200b71c and context 0x3fcdaa78 on loop 0x3fccc1cc[0m
I (4018) wifi: wifi_event_handler:WIFI_EVENT_STA_START
D (4024) wifi:Start wifi connect
E (4026) wifi:sta is connecting, return error
I (4082) wifi:AP not PMF Capable when STA requires, reject profile
D (4180) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (4180) wifi:perform scan: ss_state=0x9, chan<2,0>, dur<0,120>
D (4420) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (4422) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
D (4662) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (4664) wifi:perform scan: ss_state=0x9, chan<4,0>, dur<0,120>
D (4904) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (4904) wifi:perform scan: ss_state=0x9, chan<5,0>, dur<0,120>
D (5144) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (5146) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120>
D (5386) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (5386) wifi:perform scan: ss_state=0x9, chan<7,0>, dur<0,120>
D (5628) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (5628) wifi:perform scan: ss_state=0x9, chan<8,0>, dur<0,120>
D (5868) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (5868) wifi:perform scan: ss_state=0x9, chan<9,0>, dur<0,120>
D (6110) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (6110) wifi:perform scan: ss_state=0x9, chan<10,0>, dur<0,120>
D (6350) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (6350) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (6590) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (6592) wifi:perform scan: ss_state=0x9, chan<12,0>, dur<360,360>
D (6832) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (6832) wifi:perform scan: ss_state=0x9, chan<13,0>, dur<360,360>
D (7072) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (7074) wifi:filter: set rx policy=4
D (7074) wifi:first chan=1
D (7074) wifi:handoff_cb: status=0
D (7076) wifi:clear rc list
D (7078) wifi:clear blacklist
D (7080) wifi:send disconnect event
D (7084) wifi:connect status 1 -> 3
D (7088) wifi:disable connect timer
D (7090) wifi:clear scan ap list
D (7094) event: running post WIFI_EVENT:5 with handler 0x42078a44 and context 0x3fccd090 on loop 0x3fccc1cc[0m
D (7104) esp_netif_handlers: esp_netif action disconnected with netif0x3fccced4 from event_id=5[0m
D (7112) esp_netif_lwip: check: remote, if=0x3fccced4 fn=0x42072ad4
[0m
D (7118) esp_netif_lwip: esp_netif_down_api esp_netif:0x3fccced4[0m
D (7124) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fccced4[0m
D (7132) esp_netif_lwip: if0x3fccced4 start ip lost tmr: no need start because netif=0x3c484900 interval=120 ip=0[0m
D (7142) esp_netif_lwip: check: local, if=0x3fccced4 fn=0x42073280
[0m
D (7148) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fccced4[0m
D (7156) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (7160) event: running post WIFI_EVENT:5 with handler 0x4200b71c and context 0x3fcdaa78 on loop 0x3fccc1cc[0m
I (7170) wifi: wifi_event_handler:WIFI_EVENT_STA_DISCONNECTED
D (7178) wifi:Start wifi connect
D (7180) wifi:connect status 3 -> 0
D (7184) wifi:connect chan=0
D (7186) wifi:first chan=1
D (7188) wifi:connect status 0 -> 1
D (7192) wifi:filter: set rx policy=3
D (7194) wifi:clear scan ap list
D (7198) wifi:start scan: type=0x50f, priority=2, cb=0x420c7d28, arg=0x0, ss_state=0x1, time=7203263, index=0
D (7208) wifi:perform scan: ss_state=0x9, chan<1,0>, dur<0,120>
I (7214) wifi: retry to connect to the AP
I (7256) wifi:AP not PMF Capable when STA requires, reject profile
I (7360) wifi:AP not PMF Capable when STA requires, reject profile
D (7454) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (7454) wifi:perform scan: ss_state=0x9, chan<2,0>, dur<0,120>
D (7694) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (7694) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
D (7936) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (7936) wifi:perform scan: ss_state=0x9, chan<4,0>, dur<0,120>
D (8176) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (8176) wifi:perform scan: ss_state=0x9, chan<5,0>, dur<0,120>
D (8418) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (8418) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120>
D (8658) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (8658) wifi:perform scan: ss_state=0x9, chan<7,0>, dur<0,120>
D (8900) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (8900) wifi:perform scan: ss_state=0x9, chan<8,0>, dur<0,120>
D (9140) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (9140) wifi:perform scan: ss_state=0x9, chan<9,0>, dur<0,120>
D (9380) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (9382) wifi:perform scan: ss_state=0x9, chan<10,0>, dur<0,120>
D (9622) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (9622) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (9862) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (9864) wifi:perform scan: ss_state=0x9, chan<12,0>, dur<360,360>
D (10104) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (10104) wifi:perform scan: ss_state=0x9, chan<13,0>, dur<360,360>
D (10344) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (10346) wifi:filter: set rx policy=4
D (10346) wifi:first chan=1
D (10346) wifi:handoff_cb: status=0
D (10348) wifi:clear rc list
D (10350) wifi:clear blacklist
D (10354) wifi:send disconnect event
D (10356) wifi:connect status 1 -> 3
D (10360) wifi:disable connect timer
D (10364) wifi:clear scan ap list
D (10366) event: running post WIFI_EVENT:5 with handler 0x42078a44 and context 0x3fccd090 on loop 0x3fccc1cc[0m
D (10376) esp_netif_handlers: esp_netif action disconnected with netif0x3fccced4 from event_id=5[0m
D (10386) esp_netif_lwip: check: remote, if=0x3fccced4 fn=0x42072ad4
[0m
D (10392) esp_netif_lwip: esp_netif_down_api esp_netif:0x3fccced4[0m
D (10398) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fccced4[0m
D (10404) esp_netif_lwip: if0x3fccced4 start ip lost tmr: no need start because netif=0x3c484900 interval=120 ip=0[0m
D (10416) esp_netif_lwip: check: local, if=0x3fccced4 fn=0x42073280
[0m
D (10422) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fccced4[0m
D (10428) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (10434) event: running post WIFI_EVENT:5 with handler 0x4200b71c and context 0x3fcdaa78 on loop 0x3fccc1cc[0m
I (10444) wifi: wifi_event_handler:WIFI_EVENT_STA_DISCONNECTED
D (10450) wifi:Start wifi connect
D (10454) wifi:connect status 3 -> 0
D (10458) wifi:connect chan=0
D (10460) wifi:first chan=1
D (10462) wifi:connect status 0 -> 1
D (10466) wifi:filter: set rx policy=3
D (10470) wifi:clear scan ap list
D (10472) wifi:start scan: type=0x50f, priority=2, cb=0x420c7d28, arg=0x0, ss_state=0x1, time=10477610, index=0
D (10482) wifi:perform scan: ss_state=0x9, chan<1,0>, dur<0,120>
I (10488) wifi: retry to connect to the AP
I (10534) wifi:AP not PMF Capable when STA requires, reject profile
I (10636) wifi:AP not PMF Capable when STA requires, reject profile
D (10728) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (10728) wifi:perform scan: ss_state=0x9, chan<2,0>, dur<0,120>
D (10968) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (10970) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
D (11210) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11210) wifi:perform scan: ss_state=0x9, chan<4,0>, dur<0,120>
D (11450) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11450) wifi:perform scan: ss_state=0x9, chan<5,0>, dur<0,120>
D (11692) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11692) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120>
D (11932) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11932) wifi:perform scan: ss_state=0x9, chan<7,0>, dur<0,120>
D (12174) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (12174) wifi:perform scan: ss_state=0x9, chan<8,0>, dur<0,120>
esp32_task_info_viewer_s,23136,1950300,global_task,0,1,1080,0,fpga_gpio_task,1,1,924,0,IDLE,1,0,800,36,IDLE,1,0,796,41,button_task,2,1,1300,0,motor_task,2,1,308,0,display_task,2,3,2552,0,adc_task,2,1,300,0,fire_level_control_a_task,2,2,1440,0,fire_level_control_b_task,2,2,1436,0,mqtt_server_rx_task,2,6,1520,0,mqtt_server_heartbeat_task,2,6,532,0,Tmr Svc,2,1,1236,0,mqtt_server_task,2,6,316,0,tiT,2,18,1352,0,wifi_app_task,2,1,100,0,ota_task,2,5,3344,0,display_port_task,2,10,1616,3,BTU_TASK,2,20,6796,0,BTC_TASK,2,19,1768,0,BleRxDataTask,2,8,1292,0,BleTxDataTask,2,8,1456,0,ipc0,2,24,840,4,ipc1,2,24,844,4,sys_evt,2,20,376,0,btController,2,23,2132,0,wifi,2,23,3944,2,esp_timer,3,22,3184,0,hciT,2,22,1484,0,esp32_task_info_viewer_e
D (12414) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (12414) wifi:perform scan: ss_state=0x9, chan<9,0>, dur<0,120>
D (12658) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (12660) wifi:perform scan: ss_state=0x9, chan<10,0>, dur<0,120>
D (12900) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (12900) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (13140) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (13142) wifi:perform scan: ss_state=0x9, chan<12,0>, dur<360,360>
D (13382) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (13382) wifi:perform scan: ss_state=0x9, chan<13,0>, dur<360,360>
D (13622) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (13624) wifi:filter: set rx policy=4
D (13624) wifi:first chan=1
D (13624) wifi:handoff_cb: status=0
D (13626) wifi:clear rc list
D (13628) wifi:clear blacklist
D (13632) wifi:send disconnect event
D (13634) wifi:connect status 1 -> 3
D (13638) wifi:disable connect timer
D (13642) wifi:clear scan ap list
D (13644) event: running post WIFI_EVENT:5 with handler 0x42078a44 and context 0x3fccd090 on loop 0x3fccc1cc[0m
D (13654) esp_netif_handlers: esp_netif action disconnected with netif0x3fccced4 from event_id=5[0m
D (13662) esp_netif_lwip: check: remote, if=0x3fccced4 fn=0x42072ad4
[0m
D (13670) esp_netif_lwip: esp_netif_down_api esp_netif:0x3fccced4[0m
D (13676) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fccced4[0m
D (13682) esp_netif_lwip: if0x3fccced4 start ip lost tmr: no need start because netif=0x3c484900 interval=120 ip=0[0m
D (13694) esp_netif_lwip: check: local, if=0x3fccced4 fn=0x42073280
[0m
D (13700) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fccced4[0m
D (13706) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (13712) event: running post WIFI_EVENT:5 with handler 0x4200b71c and context 0x3fcdaa78 on loop 0x3fccc1cc[0m
I (13722) wifi: wifi_event_handler:WIFI_EVENT_STA_DISCONNECTED
D (13728) wifi:Start wifi connect
D (13732) wifi:connect status 3 -> 0
D (13736) wifi:connect chan=0
D (13738) wifi:first chan=1
D (13740) wifi:connect status 0 -> 1
D (13744) wifi:filter: set rx policy=3
D (13748) wifi:clear scan ap list
D (13750) wifi:start scan: type=0x50f, priority=2, cb=0x420c7d28, arg=0x0, ss_state=0x1, time=13755559, index=0
D (13760) wifi:perform scan: ss_state=0x9, chan<1,0>, dur<0,120>
I (13766) wifi: retry to connect to the AP
I (13810) wifi:AP not PMF Capable when STA requires, reject profile
I (13912) wifi:AP not PMF Capable when STA requires, reject profile
D (14006) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (14006) wifi:perform scan: ss_state=0x9, chan<2,0>, dur<0,120>
D (14246) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (14248) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
D (14488) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (14488) wifi:perform scan: ss_state=0x9, chan<4,0>, dur<0,120>
D (14728) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (14728) wifi:perform scan: ss_state=0x9, chan<5,0>, dur<0,120>
D (14970) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (14970) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120>
D (15210) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (15210) wifi:perform scan: ss_state=0x9, chan<7,0>, dur<0,120>
LJY
Re: ESP32-S3连不上WIFI
Postby LJY » Fri May 13, 2022 9:56 am
pmf_cfg.required 是不是设置了 1?
aacaac50
Re: ESP32-S3连不上WIFI
Postby aacaac50 » Fri May 13, 2022 10:08 am
OK,问题解决了,之前我没有主动设置这个pmf_cfg,我这边试了下在esp_wifi_set_config的时候主动加上 wifi_config.sta.pmf_cfg.capable = true;wifi_config.sta.pmf_cfg.required = false;就OK了.感谢解答.
Users browsing this forum: Bytespider and 3 guests
