ESP32C3 SPIFFS->SPIFFS_test SPIFFS: mount failed, -10025
zhang.yu
Postby zhang.yu » Wed May 18, 2022 9:16 am
Code: Untitled.cpp Select all
#define FORMAT_SPIFFS_IF_FAILED true
void setup(){
if(!SPIFFS.begin(FORMAT_SPIFFS_IF_FAILED)){
Serial.println("SPIFFS Mount Failed");
return; }
16:16:10.181 -> ESP-ROM:esp32c3-api1-20210207
16:16:10.181 -> Build:Feb 7 2021
16:16:10.181 -> rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
16:16:10.181 -> SPIWP:0xee
16:16:10.181 -> mode:DIO, clock div:1
16:16:10.181 -> load:0x3fcd6100,len:0x38c
16:16:10.181 -> load:0x403ce000,len:0x6a8
16:16:10.181 -> load:0x403d0000,len:0x2358
16:16:10.181 -> SHA-256 comparison failed:
16:16:10.181 -> Calculated: 4ab8657f6f5aa80b81c7dd649db3bd64a98999ed7c65acc5a2ab77ce80caf525
16:16:10.228 -> Expected: 6babbc7b9ea63e04e0fc89ec224f6268aa3f84392018f73ab33721f768ce2eb6
16:16:10.228 -> Attempting to boot anyway...
16:16:10.228 -> entry 0x403ce000
16:16:10.322 -> E (159) SPIFFS: mount failed, -10025
16:16:11.430 -> E (1263) SPIFFS: mount failed, -10025
16:16:11.430 -> SPIFFS Mount Failed
Example of Arduino ESP32 SPIFFS->SPIFFS_test
is there something wrong with my dev borad?
zhang.yu
Re: ESP32C3 SPIFFS->SPIFFS_test SPIFFS: mount failed, -10025
Postby zhang.yu » Fri May 20, 2022 9:52 am
I got it!
I replaced a lib file
libspi_flash.a
from esp-idf-v4.4 to ~\Arduino15\packages\esp32\hardware\esp32\2.0.3\tools\sdk\esp32c3\qspi_qspi\ .
Then, everything is fine.
Users browsing this forum: Barkrowler, PerplexityBot and 1 guest
