Greetings of the day,
Present am working on Gatt Client Example from ESP-IDF V4.4.1, am trying to connect to server by using 128-bit Service UUID
am using below structure method given in example code to copy 16bytes into structure member
static esp_bt_uuid_t remote_filter_service_uuid= {
.len = ESP_UUID_LEN_128,
.uuid = {.uuid128 = {0xfb,0x34,0x9b,0x5f,0x80,0x00,0x00,0x80,0x00,0x10,0x00,0x00,0xe9,0xfe,0x00,0x00 },},
using "memcmp(remote_filter_service_uuid.uuid.uuid128, gatts_service_uuid128, ESP_UUID_LEN_128)" to copy all bytes
Is this the correct method to copy array of elements into structure variable ? and am unable to read "128-bit Service UUID"
1)Can I use memcpy function to copy all bytes or is there any other process to copy bytes into structure member ?
2) There are 2 methods provided in ESPRESSIF forum, can i go through using README.MD or Gatt Client Example ?
please provide me the solution as soon as possible, this could help me alot to come out of these issue.
Thanking you sir,
Suraj,N
ESP32 128-bit UUID
Re: ESP32 128-bit UUID
Yes, I made changes as per example code you provided, but am unable to read/get packet from BLE Server (QN9080 MCU) to BLE Client (ESP32), what are the changes need to be done beyond provided in example code ? to enable Client Notification, Receive packet/data in client,
1) Is memcpy function necessary when using 128-bit UUID ?, How to use or define 128-bit UUID ?
2) There are 2 methods provided in ESPRESSIF getting started guide, Can i go through using README.MD or Gatt Client Example tutorial? there is a bit difference in both of them ...
Please try to solve my issue ASAP
Thanking you
Suraj, N
Thanking you
Suraj, N
Thanking you
Suraj, N
Thanking you
Suraj, N
make sure you are using memcpy, not memcmp.
Craige
Hi Craige Hales,
Yes, am using memcpy function as you said, am able to connect to server but am not able to find remote service id's (128-bit)
Please once check the below code (main.c file) and data out in serial terminal also (log.txt)
Thanking you
Suraj,N
Thanking you
Suraj,N
- LOG.PNG (16.74 KiB) Viewed 8902 times
- main.c
- (25.48 KiB) Downloaded 227 times
Users browsing this forum: No registered users and 175 guests
