Crystal recommendation for ESP32-U4DWH
nullbert
Postby nullbert » Sun May 29, 2022 5:40 pm
Hi - I am currently designing a baseboard for the ESP32-U4DWH.
I'm looking for guidelines / recommended part numbers for the 40MHz crystal. I've looked in the hardware design guide and didn't see any specifications for the crystal and capacitors.
Please advise what I should be looking for in the crystal specs; suggested part numbers are welcome.
Thank you very much!
Re: Crystal recommendation for ESP32-U4DWH
Postby Sprite » Mon May 30, 2022 3:00 am
It needs to be 40MHz and <10ppm, otherwise it's unconstrained. Capacitors depends on the internal capacitance of the crystal and your PCB layout, Adafruit has a nice bit of text about that.
nullbert
Postby nullbert » Tue May 31, 2022 2:31 am
Thank you very much for the quick reply!
