开机后卡到Touch panel not detected这里是为什么啊?
MXthor
Postby MXthor » Thu Jun 09, 2022 5:20 am
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x2a (SPI_FAST_FLASH_BOOT)
Saved PC:0x42004a54
0x42004a54: esp_spiram_test at D:/esp32/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/port/esp32s3/spiram.c:66 (discriminator 3)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x178c
load:0x403b6000,len:0xe0c
load:0x403ba000,len:0x3068
entry 0x403b626c
I (24) boot: ESP-IDF v4.4 2nd stage bootloader
I (25) boot: compile time 08:43:01
I (25) boot: chip revision: 0
I (26) qio_mode: Enabling default flash chip QIO
I (31) boot.esp32s3: Boot SPI Speed : 80MHz
I (36) boot.esp32s3: SPI Mode : QIO
I (41) boot.esp32s3: SPI Flash Size : 16MB
I (46) boot: Enabling RNG early entropy source...
I (51) boot: Partition Table:
I (55) boot: ## Label Usage Type ST Offset Length
I (62) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (69) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (77) boot: 2 factory factory app 00 00 00010000 00200000
I (84) boot: 3 storage Unknown data 01 82 00210000 00100000
I (92) boot: End of partition table
I (96) esp_image: segment 0: paddr=00010020 vaddr=3c060020 size=13fd0h ( 81872) map
I (117) esp_image: segment 1: paddr=00023ff8 vaddr=3fc98a10 size=02bdch ( 11228) load
I (119) esp_image: segment 2: paddr=00026bdc vaddr=40378000 size=0943ch ( 37948) load
I (130) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=5b158h (373080) map
I (188) esp_image: segment 4: paddr=0008b180 vaddr=4038143c size=075d4h ( 30164) load
I (194) esp_image: segment 5: paddr=0009275c vaddr=50000000 size=00010h ( 16) load
I (201) boot: Loaded app from partition at offset 0x10000
I (201) boot: Disabling RNG early entropy source...
I (205) opi psram: vendor id : 0x0d (AP)
I (210) opi psram: dev id : 0x02 (generation 3)
I (215) opi psram: density : 0x03 (64 Mbit)
I (220) opi psram: good-die : 0x01 (Pass)
I (225) opi psram: Latency : 0x01 (Fixed)
I (230) opi psram: VCC : 0x01 (3V)
I (234) opi psram: SRF : 0x01 (Fast Refresh)
I (240) opi psram: BurstType : 0x01 (Hybrid Wrap)
I (245) opi psram: BurstLen : 0x01 (32 Byte)
I (250) opi psram: Readlatency : 0x02 (10 cycles@Fixed)
I (256) opi psram: DriveStrength: 0x00 (1/1)
W (261) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version.
I (272) spiram: Found 64MBit SPI RAM device
I (276) spiram: SPI RAM mode: sram 80m
I (281) spiram: PSRAM initialized, cache is in normal (1-core) mode.
I (288) cpu_start: Pro cpu up.
I (291) cpu_start: Starting app cpu, entry point is 0x403793e0
0x403793e0: call_start_cpu1 at D:/esp32/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156
I (0) cpu_start: App cpu up.
I (586) spiram: SPI SRAM memory test OK
I (595) cpu_start: Pro cpu start user code
I (595) cpu_start: cpu freq: 160000000
I (595) cpu_start: Application information:
I (596) cpu_start: Project name: image_display
I (596) cpu_start: App version: v0.2.1-42-gcc7610d
I (596) cpu_start: Compile time: Jun 9 2022 08:42:42
I (597) cpu_start: ELF file SHA256: d0185a3a9baf8020...
I (597) cpu_start: ESP-IDF: v4.4
I (597) heap_init: Initializing. RAM available for dynamic allocation:
I (597) heap_init: At 3FC9C9D8 len 00043628 (269 KiB): D/IRAM
I (598) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM
I (598) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM
I (598) spiram: Adding pool of 8192K of external SPI memory to heap allocator
I (599) spi_flash: detected chip: gd
I (599) spi_flash: flash io: qio
I (600) sleep: Configure to isolate all GPIO pins in sleep state
I (600) sleep: Enable automatic switching of GPIO sleep configuration
I (601) cpu_start: Starting scheduler on PRO CPU.
I (602) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (602) codec: Detected codec at 0x40. Name : ES7210
I (622) codec: Detected codec at 0x18. Name : ES8311
I (622) bsp boards: Detected board: [S3_BOX]
I (622) gpio: GPIO[1]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
I (622) gpio: GPIO[0]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (622) I2S: DMA Malloc info, datalen=blocksize=640, dma_buf_count=6
I (622) I2S: I2S0, MCLK output by GPIO2
I (622) codec: Detected codec at 0x40. Name : ES7210
I (632) codec: Detected codec at 0x18. Name : ES8311
I (632) ES7210: ES7210 in Slave mode
I (632) ES7210: Enable ES7210_INPUT_MIC1
I (632) ES7210: Enable ES7210_INPUT_MIC2
I (632) ES7210: Enable ES7210_INPUT_MIC3
I (632) ES7210: Enable ES7210_INPUT_MIC4
I (642) ES7210: The ES7210_CLOCK_OFF_REG01 value before stop is 0
I (642) ES7210: Enable ES7210_INPUT_MIC1
I (642) ES7210: Enable ES7210_INPUT_MIC2
I (652) ES7210: Enable ES7210_INPUT_MIC3
I (652) ES7210: Enable ES7210_INPUT_MIC4
I (652) codec: init ES7210
I (652) DRV8311: ES8311 in Slave mode
I (662) codec: init ES8311
I (762) bsp_spiffs: Partition size: total: 956561, used: 170429
I (762) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (762) gpio: GPIO[48]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (882) gpio: GPIO[45]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (882) lv_port: Try allocate two 320 * 20 display buffer, size:25600 Byte
W (892) indev_tp: Touch panel not detected
ESP_ERROR_CHECK failed: esp_err_t 0x105 (ESP_ERR_NOT_FOUND) at 0x4037fb84
0x4037fb84: _esp_error_check_failed at D:/esp32/Espressif/frameworks/esp-idf-v4.4/components/esp_system/esp_err.c:42
file: "C:/Users/jp/Desktop/esp-box/components/lvgl/lv_port/lv_port.c" line 304
func: lv_port_init
expression: indev_init_default()
ESP_ZhouL
Re: 开机后卡到Touch panel not detected这里是为什么啊?
Postby ESP_ZhouL » Thu Jun 09, 2022 7:47 am
看起来就是触摸屏没有检测到,是不是触摸屏排线松了?
ESP_Rachel
Postby ESP_Rachel » Thu Jun 09, 2022 7:52 am
您先重新烧一下固件试一下。
如果还是不行,按照这个拆解文档,从后面打开box看一下触摸屏排线有没有松 https://github.com/espressif/esp-box/bl ... rial_v2.md
katie312
Postby katie312 » Thu Jul 07, 2022 9:37 am
您先重新烧一下固件试一下。
我也是这种情况,touch panel not detected 重新烧过固件,也拆开看过排线,没有问题,重新连接了一次
再次上电就一直处于重复重启的状态
ESP_Rachel
Postby ESP_Rachel » Tue Jul 12, 2022 3:27 am
您先重新烧一下固件试一下。
再次上电就一直处于重复重启的状态
不排除真的是硬件有问题,软件会去检查能不能检测到 touch panel,如果检测不到就会一直重启。如现象一直存在请联系售后。
