ESP32-D0WD-V3/UART/Flash/PSRAM: schematic review
SpecialCommander2
Postby SpecialCommander2 » Thu Jun 09, 2022 8:40 am
Hello, I'm trying to build a custom ESP32-D0WD-V3 board with UART, Flash, and PSRAM. It's going to be my first schematics/PCB which is that big.
Have a few questions:
  1. USB and ESD protection for FT231XS-R: did I do it right?
  2. FT231XS-R: I tried to stick to the datasheet but I'm still not sure I connected everything properly.
  3. In general, do I miss anything? Lack of decoupling capacitors? Obviously wrong resistors/capacitors values?
Would appreciate your comments.
esp.pdf
Re: ESP32-D0WD-V3/UART/Flash/PSRAM: schematic review
Postby Sprite » Fri Jun 10, 2022 1:24 am
FYI, you can also have our hardware engineers (rather than the community here) look at your design: https://www.espressif.com/en/contact-us ... ign-review
I'm missing a RC network (at least the R for it) on MCU_RST; you need this to generate a power-on-reset.
SpecialCommander2
Postby SpecialCommander2 » Fri Jun 10, 2022 9:54 am
Hello, thank you!
Will try for sure when my PCB be ready
Do you mean that instead of
I need something like
Postby Sprite » Fri Jun 10, 2022 11:50 am
Maybe, if that EN has an 1uF capacitor to ground not in that schematic. Better refer to the hardware reference guidelines, section 2.2.1.
Users browsing this forum: Baidu [Spider], Qwantbot and 1 guest
