There are instructions how to add the Espressif IDF plug-in to Eclipse (which work) but I can't find how to install the ADF.
1) Does it have to be installed manually?
2) If installing manually, where is it installed?
How to install the ADF in the Eclipse IDF tool
Re: How to install the ADF in the Eclipse IDF tool
I have exactly the same question.
I found a video online that showed how to install ADF and then run the Espressif (eclipse)- Install Tools option to install the esp-idf tools that are inside the esp-adf, but I still can't import any of the ADF examples.
I did add the ADF_PATH environment variable
I can import, build and run any of the get-started examples in esp-adf/esp-idf/examples
But when I try to import and build an example from esp-adf/examples, I can't set any esp23 target.
I can oly use "local" which does not build.
This looks like a great audio library, but it should be easier to use with Espressif IDE.....
