Esp32 Guru Meditation Error: Core 1 panic’ed (StoreProhibited). Exception was unhandled
Mozman777
Postby Mozman777 » Thu Jun 16, 2022 10:53 pm
Hello
I am trying to develop a motion detection system using the esp32 and an ultrasonic sensor.
Everything is working fine except after the pictures/data are uploaded to firebase, it throws an error "Guru Mediation" reboots , runs the loop again sends the image throws the error repeatedly. Below is my code
#include "esp_camera.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "esp_system.h"
#include "Arduino.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <SPIFFS.h>
#include <FS.h>
#include <Firebase_ESP_Client.h>
//Provide the token generation process info.
#include <addons/TokenHelper.h>
#include <string.h>
#include <time.h>
//#include "time.h"
// Select camera model
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
// Enter your WiFi credentials
#define SSID "Redmi 10"
#define PASSWORD "1favour7"
// Insert Firebase parameters
#define API_KEY "AIzaSyDc-D6UXo56aIHXEBJloHDQxM0Fta-0rvs"
#define USER_EMAIL "akpanidiong777@gmail.com"
#define USER_PASSWORD "1favour7"
#define STORAGE_BUCKET_ID "esp32-project-900f8.appspot.com"
#define FIREBASE_PROJECT_ID "esp32-project-900f8"
// Photo File Name to save in SPIFFS
#define FILE_PHOTO "/data/photo.jpg"
const char* ntpServer = "pool.ntp.org";
// Variable to save current epoch time
unsigned long epochTime;
char buffe [50];
char source[] = ".jpg";
char docPath[] = "Images/";
unsigned long getTime() {
  time_t now;
  struct tm timeinfo;
  if (!getLocalTime(&timeinfo)) {
    //Serial.println("Failed to obtain time");
    return (0);
  time(&now);
  return now;
hw_timer_t *timer = NULL;
void IRAM_ATTR resetModule() {
  ets_printf("reboot\n");
  esp_restart();
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
//Define Firebase Data objects
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig configF;
bool taskCompleted = false;
// Check if photo capture was successful
bool checkPhoto( fs::FS &fs ) {
  File f_pic = fs.open( FILE_PHOTO );
  unsigned int pic_sz = f_pic.size();
  return ( pic_sz > 100 );
// Capture Photo and Save it to SPIFFS
void capturePhotoSaveSpiffs( void ) {
  camera_fb_t * fb = NULL; // pointer
  bool ok = 0; // Boolean indicating if the picture has been taken correctly
  do {
    // Take a photo with the camera
    Serial.println("Taking a photo...");
    fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Camera capture failed");
      return;
    // Photo file name
    Serial.printf("Picture file name: %s\n", FILE_PHOTO);
    File file = SPIFFS.open(FILE_PHOTO, FILE_WRITE);
    // Insert the data in the photo file
    if (!file) {
      Serial.println("Failed to open file in writing mode");
    else {
      file.write(fb->buf, fb->len); // payload (image), payload length
      Serial.print("The picture has been saved in ");
      Serial.print(FILE_PHOTO);
      Serial.print(" - Size: ");
      Serial.print(file.size());
      Serial.println(" bytes");
    // Close the file
    file.close();
    esp_camera_fb_return(fb);
    // check if file has been correctly saved in SPIFFS
    ok = checkPhoto(SPIFFS);
  } while ( !ok );
void initSPIFFS() {
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    ESP.restart();
  else {
    delay(500);
    Serial.println("SPIFFS mounted successfully");
//ultransonic sensor pins
const int trigPin = 13;
const int echoPin = 15;
boolean startTimer = false;
unsigned long time_now = 0;
int counter = 0, time_capture = 0;
//other variables
long duration;
float distanceCm;
float distanceInch;
//int FirstDistance;
//int SecondDistance;
//double velocity;
//float Time = 2.0;
//float delayedtime = 1000*Time;
//define sound speed in cm/uS
#define SOUND_SPEED 0.034
#define CM_TO_INCH 0.393701
  while (!Serial) {
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  WiFi.begin(SSID, PASSWORD);
  Serial.printf("WiFi connecting to %s\n", SSID);
    Serial.print(".");
    delay(400);
  Serial.printf("\nWiFi connected\nIP : ");
  initSPIFFS();
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  configTime(0, 0, ntpServer);
  //Firebase
  // Assign the api key
  configF.api_key = API_KEY;
  //Assign the user sign in credentials
  auth.user.email = USER_EMAIL;
  auth.user.password = USER_PASSWORD;
  //Assign the callback function for the long running token generation task
  configF.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  Firebase.begin(&configF, &auth);
  Firebase.reconnectWiFi(true);
  timer = timerBegin(0, 80, true); //timer 0, div 80Mhz
  timerAttachInterrupt(timer, &resetModule, true);
  timerAlarmWrite(timer, 20000000, false);
  timerAlarmEnable(timer); //enable interrupt
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if (psramFound()) {
    // FRAMESIZE_ +
    //QQVGA/160x120//QQVGA2/128x160//QCIF/176x144//HQVGA/240x176
    //QVGA/320x240//CIF/400x296//VGA/640x480//SVGA/800x600//XGA/1024x768
    //SXGA/1280x1024//UXGA/1600x1200//QXGA/2048*1536
    config.frame_size = FRAMESIZE_VGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
  else {
    config.frame_size = FRAMESIZE_QQVGA; config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  timerWrite(timer, 0); //reset timer (feed watchdog)
  epochTime = getTime();
  sprintf(buffe, "%lu", epochTime);
  strcat(buffe, source);
  strcat(docPath, buffe);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  // Calculate the distance
  distanceCm = duration * SOUND_SPEED / 2;
  // Convert to inches
  distanceInch = distanceCm * CM_TO_INCH;
  // Prints the distance in the Serial Monitor
  Serial.print("Distance (cm): ");
  Serial.println(distanceCm);
  Serial.print("Distance (inch): ");
  Serial.println(distanceInch);
  if (distanceCm <= 50 && startTimer != true) {
    Camera_capture();
    startTimer = true;
  } else if (distanceCm > 50) {
    startTimer = false;
    time_capture = 0;
  } if (distanceCm <= 50) {
    if (++time_capture > 4) {
      time_capture = 0;
      Camera_capture();
      Serial.println("Over Time");
  delay(500);
void Camera_capture() {
  capturePhotoSaveSpiffs();
  delay(1);
  if (Firebase.ready() && !taskCompleted) {
    taskCompleted = true;
    String documentPath = docPath;
    FirebaseJson content;
    Serial.print("Uploading picture... ");
    //MIME type should be valid to avoid the download problem.
    //The file systems for flash and SD/SDMMC can be changed in FirebaseFS.h.
    if (Firebase.Storage.upload(&fbdo, STORAGE_BUCKET_ID /* Firebase Storage bucket id */, FILE_PHOTO /* path to local file */, mem_storage_type_flash /* memory storage type, mem_storage_type_flash and mem_storage_type_sd */, buffe /* path of remote file stored in the bucket */, "image/jpeg" /* mime type */)) {
      Serial.printf("\nDownload URL: %s\n", fbdo.downloadURL().c_str());
    else {
      Serial.println(fbdo.errorReason());
    content.set("fields/ImgUrl/stringValue", fbdo.downloadURL().c_str());
    content.set("fields/velocity/stringValue", String(distanceCm).c_str());
    //content.set(fields/ImgUrl/stringValue", fbdo.downloadURL().c_str());
    Serial.print("Uploading data... ");
    if (Firebase.Firestore.createDocument(&fbdo, FIREBASE_PROJECT_ID, "" /* databaseId can be (default) or empty */, documentPath.c_str(), content.raw())) {
      Serial.printf("ok\n%s\n\n", fbdo.payload().c_str());
    else {
This are the errors i got
Screenshot (251).png (91.13 KiB) Viewed 4563 times
Screenshot (250).png (93.47 KiB) Viewed 4563 times
Using the Esp decoder i inputted the backtrace but i dont seem to get the issue
Decoding stack results
0x400e93b0: gpio_set_level at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/hal/esp32/include/hal/gpio_ll.h line 427
0x400e5ad9: __digitalWrite at C:\Users\ACER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32\esp32-hal-gpio.c line 126
0x400d3660: loop() at C:\Users\ACER\Desktop\speed/speed.ino line 253
0x400e8065: loopTask(void*) at C:\Users\ACER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32\main.cpp line 50
Please help as this has been disturbing me for days please
Users browsing this forum: Applebot, Google [Bot], PerplexityBot and 3 guests
