On a board with a ESP32-U4WDH mcu, I cannot program the the embedded flash. The board used to be populated with a ESP32-D2WD and there programming worked as it should.
As recommended in the datasheet, GPIO16, GPIO17, SD_CMD, SD_CL, SD_DATA_0 and SD_DATA_1 have no external connection.
I already upgraded to the latest stable idf-tools (4.4.1), but programming keeps failing. It seems there is no communication with the flash.
Output of: esptool.py --port COM7 flash_id
esptool.py v3.3-dev
Serial port COM7
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting...
Detecting chip type... ESP32
Chip is ESP32-U4WDH (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 94:b5:55:52:e2:78
Uploading stub...
Running stub...
Stub running...
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
Manufacturer: ff
Device: ffff
Detected flash size: Unknown
Hard resetting via RTS pin...
What can I do to fix this? Any ideas?
Regards,
Stef
Cannot program ESP32-U4WDH Flash, flash not detected.
Stef_Esp32
Stef_Esp32
Re: Cannot program ESP32-U4WDH Flash, flash not detected.
In the mean time I have found one possible cause:
Pin MTDI (strapping pin) is pulled to 3.3V on this board, this means VDD_SDIO is connected to the 1.8V LDO.
In the datasheet, in the recommended operating conditions, it says the minimum operation voltage for VDD_SDIO (3.3V mode) is 2.3V for parts with no embedded flash and 3.0V for parts with 3.3V embedded flash.
This raises some questions, I hope anyone can answer:
1) Is this a likely cause for the problem I see?
2) Why is there no specification for VDD_SDIO (1.8 V mode)?
3) Is embedded flash always 3.3V?
4) Why did this work with the ESP32-D2WD?
5) Should I connect and external 3.3V or pull MTDI low?
I think I found the answer to 3) and 4) in an older version of the datasheet (version 3.1):
• ESP32-U4WDH (with a 3.3 V flash embedded): this minimum voltage is 3.0 V;
• ESP32-D2WD (with a 1.8 V flash embedded) and other chips (no flash): this minimum voltage is 2.3 V;
There is no recommended operating voltage spec for the flashes in the datasheet. From what I see, I would say the D2WD flash can handle at least 1.8V - 3.6V and the U4WDH flash 3.0V - 3.6V. Would be nice to mention this explicitly in the datasheet.
I will proceed with either pulling MTDI low or connecting 3.3V to VDD_SDIO for test for now. Whichever is easiest to patch on the board.
Regards,
Stef
Regards,
Stef
Stef
Stef
Note that a third option is to burn an eFuse to fix the flash voltage, independent of the bootstrap pins.
Stef_Esp32
Thanks, I was not aware of that option.
I had already wired the 3.3V to VDD_SDIO and that solved the flash problem.
Now I removed the wire and burnt these fuses to 1
XPD_SDIO_FORCE Ignore MTDI pin (GPIO12) for VDD_SDIO on reset = 1 R/W (0x1)
XPD_SDIO_REG If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset = 1 R/W (0x1)
XPD_SDIO_TIEH If XPD_SDIO_FORCE & XPD_SDIO_REG, 1=3.3V 0=1.8V = 1 R/W (0x1)
First I tried without XPD_SDIO_REG as 3.3V would not require the (1.8V) regulator but that did not work. But with all 3 set to 1, I have 3.3V on VDD_SDIO without an external wire. Much better.
Re-tested flash programming after this and that was OK as well.
So all solved. Thanks for listening and for your help.
Stef
Stef
This piqued my interest. I couldn't find anywhere in the datasheet - or in the technical reference manual, or hardware integration guide - any mention of GPIO16, GPIO17 recommending not being connected for flashing firmware.
Right now I have these connected to a button and used as an output to an LCD (not an input to the ESP32).
What are the specific details around this constraint? TIA!
It depends on the chip itself. Because of pad layout reasons, some ESP32 chips with internal flash use GPIO16/17 as signal pins, in which case it's better not to use them. Also, if you use PSRAM, these pins are occupied. If your design has a (module with an) ESP32 with external flash and no psram, GPIO16/17 are available for your use.This piqued my interest. I couldn't find anywhere in the datasheet - or in the technical reference manual, or hardware integration guide - any mention of GPIO16, GPIO17 recommending not being connected for flashing firmware.
Users browsing this forum: ChatGPT-User, YisouSpider and 4 guests
