Use case: I want to feed ESP32 chips wifi credentials using BLE and then start a wifi mesh (I presume this will require deactivating BLE mode since wifi mesh and BLE can't operate simultaneously because of a single antenna?), so the root can disseminate data to rest of the wifi mesh chips. But if user transports an already provisioned chip in the vicinity of a new router or existing router password is changed, ESP32 won't be able to connect to the router and wifi mesh will trigger the MESH_NWK_LOOK_FOR_NETWORK event. In such an event, I'd like to move the ESP32 chip back into BLE mode to re-provision it with new/correct wifi ssid/password. Any obvious way to achieve this short of a hard reset on the chip?
My approach was to let the MDF_EVENT_MWIFI_NO_PARENT_FOUND get triggered, at which point I could deactivate the wifi mesh and reactivate the BLE. The only problem I find with this approach is that it takes about 60 network scans before which MDF_EVENT_MWIFI_NO_PARENT_FOUND gets triggered, which is a very long time from an end user's perspective. Any way to reduce the number of scans after which the MDF_EVENT_MWIFI_NO_PARENT_FOUND event gets triggered? Any other suggestions on how to achieve this?
How to switch between wifi mesh and BLE
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
