Can't flash esp32 - boot button not working
usernametoolong
Postby usernametoolong » Fri Jun 24, 2022 12:51 pm
Hi all!
I'm having a problem with an esp32 that shows up on /dev/ttyUSB0
I have some code in Platform.io that works with some other esp32 devices and I wanted to flash this devices with the same code.
Unfortunately it refuses.
Now I just tried erasing the flash completely and I get this result:
esptool.py erase_flash        ─╯
esptool.py v4.1
Found 1 serial ports
Serial port /dev/ttyUSB0
Connecting......................................
/dev/ttyUSB0 failed to connect: Failed to connect to Espressif device: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
A fatal error occurred: Could not connect to an Espressif device on any of the 1 available serial ports.
When it says connecting I hold down the boot button until the end but nothing happens.
This is the device I'm using:
I've also tried pressing the EN button and then boot - but that also doesn't work.
Any help is appreciated.
Thanks!
Re: Can't flash esp32 - boot button not working
Postby Sprite » Fri Jun 24, 2022 11:54 pm
As a last resort - while it is connecting, can you hold the 'boot' and press 'en' shortly?
