Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Posted: Mon Jun 27, 2022 10:59 am
by preetjhota
I am trying to run 6 parallel tasks on esp32 but it showing the following error:
Core 0 register dump:
PC : 0x400868b4 PS : 0x00060033 A0 : 0x80085442 A1 : 0x3ffb0b50
0x400868b4: xTaskIncrementTick at C:/Users/preet/esp/esp-idf/components/freertos/tasks.c:3157
A2 : 0x00000001 A3 : 0x80059301 A4 : 0x00000000 A5 : 0x00000132
A6 : 0x00000003 A7 : 0x00060023 A8 : 0x00000000 A9 : 0x3ffb0b30
A10 : 0x3ffb26b8 A11 : 0x00000003 A12 : 0x00060b20 A13 : 0x00060b23
A14 : 0x3ffb6300 A15 : 0x3ffb53fc SAR : 0x00000016 EXCCAUSE: 0x0000001c
EXCVADDR: 0x80059309 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace:0x400868b1:0x3ffb0b500x4008543f:0x3ffb0b70 0x40085199:0x3ffb0b90 0x400826e9:0x3ffb0ba0 0x400e4b6b:0x3ffb6210 0x400d18ef:0x3ffb6230 0x40086462:0x3ffb6250 0x40087991:0x3ffb6270
0x400868b1: xTaskIncrementTick at C:/Users/preet/esp/esp-idf/components/freertos/tasks.c:3156
0x4008543f: xPortSysTickHandler at C:/Users/preet/esp/esp-idf/components/freertos/port/port_systick.c:167
0x40085199: _frxt_timer_int at C:/Users/preet/esp/esp-idf/components/freertos/port/xtensa/portasm.S:329
0x400826e9: _xt_lowint1 at C:/Users/preet/esp/esp-idf/components/freertos/port/xtensa/xtensa_vectors.S:1111
0x400e4b6b: cpu_ll_waiti at C:/Users/preet/esp/esp-idf/components/hal/esp32/include/hal/cpu_ll.h:183
(inlined by) esp_pm_impl_waiti at C:/Users/preet/esp/esp-idf/components/esp_pm/pm_impl.c:837
0x400d18ef: esp_vApplicationIdleHook at C:/Users/preet/esp/esp-idf/components/esp_system/freertos_hooks.c:63
0x40086462: prvIdleTask at C:/Users/preet/esp/esp-idf/components/freertos/tasks.c:3973 (discriminator 1)
0x40087991: vPortTaskWrapper at C:/Users/preet/esp/esp-idf/components/freertos/port/xtensa/port.c:131
ELF file SHA256: 142fe637d0302132
Rebooting...
Re: Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Posted: Mon Jun 27, 2022 11:18 am
by Sprite
Hard to say. There's no limit in the amount of tasks that FreeRTOS can run, so that's not the issue. Could be a memory corruption issue elsewhere in your code that causes FreeRTOS to fail. Suggest you turn on stack checking and heap checking fuctions.
Posted: Fri Feb 03, 2023 12:46 am
by fatmaEK
did you fix this?
