ATECC608 not detected by ESP32
mathteus35
Postby mathteus35 » Mon Jun 27, 2022 1:59 pm
Hi, I'm trying to use the adafruit attec608 breakout board with my esp32 dev-kit(esp32-wroom).
I connected the board using the pins: SCA with pin 21 from esp32, SCL with pin 22, GND with GND, VCC with my 3.3v power pin) but I'm unable to find the chip.
When I compile the following example using plafatorm IO, it returns an erro code 2 from all address.
link with photos https://imgur.com/gallery/0Aebu6m
#include <Arduino.h>
#include <Wire.h>
    Wire.begin(21, 22, (uint32_t) 400000);
    Serial.println("\nI2C Scanner");
    byte error, address;
    int nDevices = 0;
    Serial.println("Scanning...");
    nDevices
    for(address = 1; address < 127; address++ ) {
        Wire.beginTransmission(address);
        error = Wire.endTransmission();
        Serial.printf("ADDRESS=%d -- ERROR=%d\n", address, error);
        if (error == 0) {
            Serial.print("I2C device found at address 0x");
            if (address<16) {
                Serial.print("0");
            Serial.print(address,HEX);
            Serial.println("  !");
            nDevices++;
        } else if (error==4) {
            Serial.print("Unknown error at address 0x");
            if (address<16) {
                Serial.print("0");
            Serial.println(address,HEX);
    if (nDevices == 0) {
        Serial.println("No I2C devices found\n");
  delay(5000);
